7.5 rear axle help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-08-2001, 04:29 PM   #1 (permalink)
Member # 1408
Send a message via AIM to RockRanger
Post 7.5 rear axle help
My pinion seal is going in my rear axle and am planning on changing it. I am wondering if i need to replace the crush sleeve as well when i pull the seal or can I just take the flange off replace the seal and bolt it back together. Also what is the torque spec for the pinion nut. I left my manual at my parents house and they can't find anything in it <IMG SRC="smilies/rolleyes.gif" border="0">
Matt
93 Ranger on 37"s
RockRanger is offline   Reply With Quote Quick reply to this message
Old 10-08-2001, 04:51 PM   #2 (permalink)
Member # 5821
Post
Matt I am not a pro at diffs but if you have a crush sleve I don't think you can just replace it with out re-setting the lash on the gears. If no one with more knoldge responds to this I would call a gear shop and check with them before you possibly cost your self more than expected. Good luck!
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote Quick reply to this message
Old 10-08-2001, 05:38 PM   #3 (permalink)
Member # 6576
Post
Matt, In repsonse.. It is not manditory that you replace the sleeve, even though it is reccomended. The proper way to do this is to yank the axles, and get a needle type inch pounds torque wrench to measure bearing load. Then take it apart, change the seal, I would use a new nut, but you don't have to if you use some more loctite, and tighten the nut down until there is no pinion end-play, and the bearing preload is the same. If you want to be even more exact, you can pull the carrier, and measure bearing load of just the pinion. Or you can do it with the axles if you really want to...
Brian Whitford
4554 OCD Racing
Rage 4th............ "safety is our #2 concern"
1uglyranger is offline   Reply With Quote Quick reply to this message
Old 10-08-2001, 07:14 PM   #4 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
Post
I would not worry about the crush sleeve, just replace the seal, and retorque the pinion nut to factory spec (180 ft lb on an 8.8, probly same for 7.5) and check that there is not excessive endplay. There will be some, but more than .050" (less than 1/16) is too much.
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote Quick reply to this message
Old 10-09-2001, 02:02 PM   #5 (permalink)
Member # 792
Post
They way I was told you can do this with crush sleeves is to mark the position of the nut and tighten it back to the same exact position. This should work fine.
Or you can do it right <IMG SRC="smilies/wink.gif" border="0">
Dan-H is offline   Reply With Quote Quick reply to this message
Old 10-09-2001, 02:15 PM   #6 (permalink)
Member # 7248
Post
What Dan-H said is correct...just mark the nut and the pinion shaft and re-"clock" the nut back exactly where you found it. Don't mark yoke or flange, because you may not hit same set of splines. Set the parking brake really tight, and chock wheels both sides, and you probably won't need a special tool to hold the yoke or flange. Use strongest grade of locktight on the nut when you re-install.
If you do use a new crush sleeve, then you need an inch-pound torque wrench or weight on a lever trick to set the bearing pre-load, and that is tricky with the carrier still in, as you have only the backlash available to "feel" the preload. Also the pre-load spec is different for used and for new bearings..best to just re-clock the old nut.
The backlash and contact pattern are controlled by shims, and will not be effected by crush sleeve or pinon nut torque.
-KF-
Kevbo is offline   Reply With Quote Quick reply to this message
Old 10-09-2001, 03:04 PM   #7 (permalink)
Member # 1408
Post
Sounds like i can do it with out much of a problem then. real quick though will having a lock right installed make the mark theory still work? Plan on doing friday night or saturday morning.
matt
93 Ranger on 37"s
Old 10-09-2001, 03:27 PM   #8 (permalink)
Member # 792
Post
Lock tite shouldn't affect the torque. Its gonna be up over 150, maybe even 175.
locktite the nut, the threads and the washer.
Also, put some RTV sealant on the splines of the pinion so it won't leak through the center of the yoke.
[ 10-09-2001: Message edited by: Dan-H ]
01 TJ
Old 10-09-2001, 03:40 PM   #9 (permalink)
Member # 1408
Post
Alright sounds good dan thanks
matt
93 Ranger on 37"s
Old 10-09-2001, 06:25 PM   #10 (permalink)
Member # 6576
Post
A lock right will not affect anything, for you do not have to move anything to install it. Just pull the spiders, and install the locker...
Brian Whitford
4554 OCD Racing
Old 10-09-2001, 06:49 PM   #11 (permalink)
Member # 1408
Post
I already have the lock right installed. I was just making sure having in there wouldn't screw up retorqueing the pinion nut. I remember when i put it in think how big of PIA it looked to get the c clips out and don't want to have to mess with it.
Matt
93 Ranger on 37"s
Old 10-09-2001, 06:58 PM   #12 (permalink)
Member # 6576
Post
Its really not as hard as it looks. Wait until you go to 5:13 gears. Then it gets a little crazy.
Brian Whitford
4554 OCD Racing
