Steering kit - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-28-2004, 06:32 PM   #1 (permalink)
Member # 36090
Steering kit
Anyone useing the stone crusher steering kit (on a early bronco)? If so do you have it on top of the knuckels or on the bottom?
smitty66 is offline   Reply With Quote Quick reply to this message
Old 10-04-2004, 07:39 PM   #2 (permalink)
Member # 26164
It was designed for the EB and it looks like the ends are below and the drag link is on top. Email Anthony Terry and ask him about running it knuckle under. It should be doable.
Jess James is offline   Reply With Quote Quick reply to this message
Old 10-04-2004, 07:52 PM   #3 (permalink)
3d Artist for Hire!
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
I'm going to be running that setup for my F-150 here very soon, and from what I've read on his site, you can run either. I'm thinking of running them on top, unless someone advises otherwise....
Sometimes I parkerize stuff. PM for info..
animator is offline   Reply With Quote Quick reply to this message
Old 10-04-2004, 08:52 PM   #4 (permalink)
Member # 26592
I have been hearing that if you run it on top it will put alot of stress on the bolt where the draglink and tirerod meet.
1993 F150 XL 4X4
393ci Stroker
4.56 gears, D44 Solid front, detroit locked 9" rear, ZF S5-42, Twin-Stick 205, 38.5" Hawgs
fordperf351w is offline   Reply With Quote Quick reply to this message
Old 10-04-2004, 09:02 PM   #5 (permalink)
3d Artist for Hire!
animator's Avatar
Member # 13701
That's my main concern too, but from what I'm led to believe is that it can take the stress. I'd be interested to hear if anyone has run them on top and broken that bolt...
Old 10-05-2004, 06:37 AM   #6 (permalink)
Member # 26164
Maybe a "high steer" arm would work if you have a flat top knuckle.
Old 10-05-2004, 07:16 PM   #7 (permalink)
Member # 17606
I have been running the performance unlimited rock proof on top of my EB for about a year and a half with no probs turning 35's and stock EB PS. The only thing I've noticed is that the jamb nuts on the tie rod came loose after my first run. Since then theyve been tightened and locktited and have been fine.
Klaus
"I believe that children are the future, unless we can stop them now!" HJS
2drnkecv is offline   Reply With Quote Quick reply to this message
Old 10-05-2004, 09:57 PM   #8 (permalink)
Member # 36090
Got the stone crusher on tonight. A very nice kit, easy to put on and well built.Even looks to good to be on my ugly rig.I didn't put it on top. He told me when I ordered it that with only the 2 inch lift I have it would more than likely cause some bad bump steer.Due to the change in the angel between the trac bar and drag link. I think he said it's best to have at least 3.5 inch lift to run it on top.Any way this is a nice kit and would buy it again.
Old 10-06-2004, 10:34 AM   #9 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Thats correct, only if both the tie rod and drag link are put on top.
the best setup is tie rod on bottom and drag link on top
Mark
