E4od planetaries in a C6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2004, 09:58 AM   #1 (permalink)
Member # 14848
Have any of you ever done this? Are the e4od planetary sets a direct swap or is this something I would have to take my box to a tranny shop to have worked on?
Also, when swaping a 205 into the place of a BW 1356 I see where I need to modify the adapter to clear the shift rail, but I read on here once that you need to "fill a hole" in the adapter as well. I am not seeing it. If any of you could describe it a little better to me I would appreciate it.
Thanks,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 10-23-2004, 03:31 PM   #2 (permalink)
Member # 23707
Send a message via AIM to BigManBrock07
As far as the t-cases go, you need to make sure the splines match, if so you're golden.
The shift rails need to be cut in the adapter and the hole should be for the speedo cable. That is unless your cable comes from your rearend in the truck. Certain years ran a digital speedo to the pinion inside the case. The 205 also has a hole for a speedo. Just make sure you use what you need and cap off what you don't.
Phil
Originally Posted by Co Pilot
yeah.... your wifey poo cant wear all the pretty pantys she wants.. but if she aint giving it up... whats the point?
quote:
He could have used a bigger hammer though, and then things break faster so you can move on to the next step of cussing quicker.
BigManBrock07 is offline   Reply With Quote Quick reply to this message
Old 10-23-2004, 05:08 PM   #3 (permalink)
Member # 25159
Send a message via AIM to orange150
why dont you just spend another $30 and get the right tail housing, thats what i did. i modded my old 13-56 tailhousing to work with the 205 and didnt feel safe at all so i just bought the right one.
as for the planetary gear; i have read it will swap right in, but am not certain. i hope someon keys in because i am curious as well.
'75 CJ-5
orange150 is offline   Reply With Quote Quick reply to this message
Old 10-24-2004, 01:10 AM   #4 (permalink)
Member # 14848
Where'd you get the factory adaptor? Junk yard or Ford dealership. I kind of figured ford wouldnt have them around anymore and there are very few of the c6/205's in junkyards around here.
I hope someone knows definitively too about the planetaries. I searched for an hour on here last night and didn't find anything and I have searched for a few days off and on on the net and can find nothing except shops offering to rebuild your box with the e4od forward and reverse planetaries...
Anyhow, thanks for your replys so far.
Jason
Old 10-24-2004, 08:19 AM   #5 (permalink)
Wildjon300ci's Avatar
Member # 20850
Send a message via AIM to Wildjon300ci
E4OD planitaries in my c-6...look up "C6 wide ratio kits" on google and see what they put in the kits....go to the ford dealer and buy everything needed.
Wildjon300ci is offline   Reply With Quote Quick reply to this message
Old 10-24-2004, 09:37 AM   #6 (permalink)
Member # 14848
I looked it up and got a prats list. This is good info, thanks. I was kind of hoping I could buy a core E4od and put this together. Looks lik eI have to get the ford kit to get all of the special needle bearings??? Do you have to have the needle bearings or can you just instal the planataries...
Thanks,
Jason
Old 10-24-2004, 11:33 AM   #7 (permalink)
broncoformudv's Avatar
Member # 24310
Send a message via Yahoo to broncoformudv
E4OD wide ratio kit
You can just install the gears themselves and keep using the thrust washers in your C-6 or you can go all out and install the needle bearings if you do that then I believe there is some maching involved
broncoformudv is offline   Reply With Quote Quick reply to this message
Old 10-24-2004, 03:06 PM   #8 (permalink)
Member # 25159
i found my tail housing off line, look in the classifieds here or at www.fordtrucks.com, thats where i got mine.
'75 CJ-5
Old 10-24-2004, 03:51 PM   #9 (permalink)
Member # 19022
Send a message via AIM to p575
so will a used E40D transmission be a good place to find the planateries? or should they be bought new?
justin
p575 is offline   Reply With Quote Quick reply to this message
Old 10-24-2004, 07:13 PM   #10 (permalink)
Member # 14848
Thanks for the info guys. I will start looking for a core e4od.
Later,
Jason
Old 10-24-2004, 09:03 PM   #11 (permalink)
Member # 25159
p575, im just going to look for a cheap, used E4OD and pull it apart.
'75 CJ-5
Old 10-25-2004, 10:16 PM   #12 (permalink)
Member # 27349
Send a message via Yahoo to Hoxviii
I have a C6 to NP205 tailhousing if you need it. PM me and we can talk. FYI it ships at 35 lbs
Justin
Hoxviii is offline   Reply With Quote Quick reply to this message
Old 10-25-2004, 10:40 PM   #13 (permalink)
Backncardr's Avatar
Member # 24747
justin
Depending on the core price (if any). If yer using a used set check the free play between the individual gears and the inner shaft-you don't any. Also check the ends of the gear teeth-if they are like razor sharp-they are worn-don't use.
E4OD planets will install into a C-6 for a lower 1st and 2nd, but the entire assembly must be used including the shell.
NRA Life
CRPA Life
Backncardr is offline   Reply With Quote Quick reply to this message
Old 10-26-2004, 05:31 AM   #14 (permalink)
Member # 14848
I found a Core tranny at my local pick and pull for $100 yesterday. I haven't pulled it apart yet, but I will check the things you mention. They told me they'de take the trans back if the parts I needed were smoked, so I am going to come out a bit better than the $400 ford gets for the kit.
Thanks for all of the info guys.
Jason
Old 10-26-2004, 05:26 PM   #15 (permalink)
Member # 25159
could that planetary gear also be called the "overdrive" planetary gear?
'75 CJ-5
Old 10-27-2004, 01:08 AM   #16 (permalink)
Member # 14848
It should be called a "forward Planet Assy. 6 pinion" (this is from the ford motor sports kit instructions I downloaded from their web site) Replacement part number F81Z-7A398-CA
I am by no means an expert, I was asking the question in the first place, but this is what my research shows... So, good luck
Later,
Jason
Old 10-27-2004, 06:33 AM   #17 (permalink)
Member # 25159
gotcha, so this http://cgi.ebay.com/ebaymotors/ws/eB...930784486&rd=1 would not be it then.
'75 CJ-5
Old 11-30-2004, 03:33 PM   #18 (permalink)
Member # 25159
looking over all the parts on Ford Racing, is it that much cheaper to peice it together than to just buy the whole kit?
'75 CJ-5
Old 11-30-2004, 04:37 PM   #19 (permalink)
Member # 8411
I myself bought the kit. I found it easier than trying to find good used parts or having to order individual pieces. My first one I did piece it together with used E4OD parts, found it time consuming and not really worth the savings. That's just my opinion though, I'm kinda lazy
HUH?
maritime mudder is offline   Reply With Quote Quick reply to this message
Old 11-30-2004, 07:33 PM   #20 (permalink)
Member # 25159
hmm... i too am quite lazy. but boy $350 or whatever it is, is still a good bit of money. damn, expensive yet fun hobby.
'75 CJ-5
