Member # 33787
F.I to CARB
I just swaped in a 351w (carb)inplace of a 302 (F.I.)What fuel reg. pressure do I need to run?Do I need to install a new one?Where is the best place to install it?Is the top fuel line the supply or return ?
Thanks, Patrick |
Member # 17313
what year truck?
dual or single pumps?
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 17313
well, 89' should be two pumps still, my 89' F-150 was..
all I did was bypass the timer for the intank pump(timer is under the hood) then unplug, bypass, and remove the high pressue pump on the frame.. 5PSI all day long.. My truck has had this setup for 3 years now, I know a few others that did the same.
Member # 17313
the pump on the frame rail will be the high pressure pump
The timer is someplace under the dash. IIRC, the wires are pink. I want to think that I just ran a wire from the fuse box to the fuel pump power wire after the inertia switch. Looking at the diagram in a chiltons manual will help more though.. It was a few years ago when I did it
Member # 33787
is the "timer" that you are referring to and the inertia switch the samething? I found the intertia switch,your right it has a plug going to it with a pink wire and a ground wire.Do I just make the pink wire a key on hot wire?
Member # 37273
I could be wrong here but I thought the 89 + models only had the one highpressure in tank fuel pump. If that is the case you will not be able to use the high pressure fuel pump to provide fuel to the Carb. I'm running a low pressure electric fuel pump mounted back by the tank to provide fuel to the Carb., but I did this because I was to lazy to replace my mechanical fuel pump. I didn't switch from FI to Carb. Well I did kind of because I was experimenting with fuel injection on my rig but thats beside the point. Look for a pump on the driverside frame rail. If you can't find one then you have the single high pressure intank fuel pump. It may be possible to use this pump provided you could find a regulator to drop the pressure to at least 6 psi.
