1967 Dana 60 Rear Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2004, 10:29 AM   #1 (permalink)
Member # 28881
I've got a line on a Dana 60 out of a 1967 Mercury PU. I've been told it is a full float, 3.90 gears with a posi. SRW and truck was 2WD. Are there any problems I should be aware of with a Dana 60 this old? What's the spline count and axle shaft thickness? Are lockers and gears readily available?
98yj is offline   Reply With Quote Quick reply to this message
Old 10-28-2004, 11:53 AM   #2 (permalink)
Member # 848
It's probably just a run of the mill 60. It's probably got a course spline pinion, but that's no big deal. You'll probably regear it anyway. You'll need a new yoke if you regear though. It probably has the course 16 spline axles, and small bore spindles. I think a lincoln locker is your only option unless you use 30 spline shafts.
SNOWTREK.org
Nobody is offline   Reply With Quote Quick reply to this message
Old 10-29-2004, 01:10 PM   #3 (permalink)
ddestruel's Avatar
Member # 20999
1967 merc, should be a small spindle 30 spline, are you sure its full float, i thought mercs were only 1/2 ton and came with the semi float 30 spline 5 or 5.5 D60's, if its LSD, then its most likely a Power Lok, stack the clutches right and you could get pretty good service out of it. Nothing like a Detroit but pretty good service just the same.
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA,
and some
I miss my
Support Frank the Tank
ddestruel is offline   Reply With Quote Quick reply to this message
