Member # 34083
Steering Problems in EB..
I just installed my 2" body lift... I had all the bolts loosened around the steering column. The plate on the firewall off After I was done The steering is Stiff as hell. Even the turn signal switch is tight. A quarter turn in either direction results in a CLUNK..... this was the Ujoint that go's into the steering box... The Previous owner put on a 2 wd F150 box.. Is this box longer than stock and so its shortened my steering shaft too much When I increased the angle?? Do I need a dual U joint set up now. Any help would be appreciated..
Thanks Aaron
[B][COLOR="White"]KK6DAD[/COLOR][/B] [B][SIZE="4"][COLOR="DarkRed"]www.Norcalbroncos.com[/COLOR][/SIZE][/B] |
Member # 17606
When I did my BL I needed to add a second u-joint to the shaft. Now I can steer with one finger.
"I believe that children are the future, unless we can stop them now!" HJS |
#4 (permalink) | |
Member # 6052
Where you at in Sac?
'73 Bronco Growing pile of parts. 4 years is long enough! |
Member # 16864
had the exact same problem this sumer on my eb best thing to do is get a custom two joint shaft i was short on money at the time i was able to move the column down and toward the box with brackets i fabed up to relieve the bind
69 BRONCO stock p/s a/t 69 BRONCO 4.56 9"spool qjet f100p/s 35s |
Member # 34083
Thanks I will try and order a new shaft. What brand?? Who has the best prices? Do i have to cut the shaft to fit or will they make it to fit?
Thanks Aaron
Member # 26739
I used 2 spicer steering joints and a solid shaft. Bullit proof. Bought it from Pete at BP before he went under and before I had my shop. I haven't needed to buy them agian, so I do not know the part numbers. They are about 50 bucks each and splined accordingly. Try calling Driveline Service, or see if Pete still answers the phone.
[url]www.norcalbroncos.com[/url] |
