Electronic 1356 problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-10-2004, 07:15 AM   #1 (permalink)
nights end here
FlexCJ5's Avatar
Member # 35217
A buddy and i are having major problems w/ the 4x4 on his fullsize TTB bronco. The t case had 4 wheel high for about week, but no low range. now we've lost 4 wheel high too. Switch is good. Assuming the motor is good since it worked last week and hasn't been wheeled since. We are looking at the computer control box under the pass. kick panel. Anybody know what the little red light and ?reset? button does? What else should we check? Gonna swap the case out eventully when we do the SAS but gotta make this work for now.
FlexCJ5 is offline   Reply With Quote
Old 11-10-2004, 10:31 AM   #2 (permalink)
icebreaker88's Avatar
Member # 25609
I had the triangular shaft that goes into the shift motor break before and the t-case was stuck in Nuetrel(sp) The shaft would just spin freelly.
74 Bronco,302,C4,dana20,twin sticked,1350 shafts, D44,4.88,spool, w/warn shafts&CTM's,9",4.88,spool, superior shafts,38.5x15 boggersw/beadlocks, JBG 5.5" superflex susp.Extended arms,Ram Assist, Durabak inside n out
[URL="http://www.supermotors.org/vehicles/registry/detail.php?id=4052"]http://www.supermotors.org/vehicles/registry/detail.php?id=4052[/URL]
icebreaker88 is offline   Reply With Quote
Old 11-10-2004, 06:03 PM   #3 (permalink)
Offrhoder4x4's Avatar
Member # 15004
Send a message via AIM to Offrhoder4x4
Work your way from the case to the switch. Pull the motor and turn the shaft by hand to be sure you have all selections. While the motor is out, pull it apart and clean it. It's a common problem for the contacts to get dirty and weird out or completely stop working.
I'm not stuck, I'm temporarily stationary.
91 Xsport, 60's, doubler, 39.5s
Offrhoder4x4 is offline   Reply With Quote
Old 11-11-2004, 12:23 AM   #4 (permalink)
Member # 25451
Send a message via AIM to kf4amu
What do the indicator lights say?
-Will
89 XLT 460
kf4amu is offline   Reply With Quote
Old 11-12-2004, 06:46 AM   #5 (permalink)
Member # 11612
Go to a junkyard buy a manual for $125-150 and be done with it.
[COLOR=DarkGreen]94 Bronco EB- ZF 5SP, SAS ongoing[/COLOR]
[COLOR="DarkOrange"]Corley Body Works- RestoMods & Classic Restoration[/COLOR]
[COLOR=Red]Need Scout Parts? [url]www.jpscout.com[/url][/COLOR]
Franklin is offline   Reply With Quote
