1979 Ford F250 Dana 60 rear question
Are they all 35 spline? And what is fair market value for one assuming good condition and open with 3.54 gears? 100? 200?
Just go... Passionately centerist. We're slowly being killed by the far left and far right. |
#3 (permalink) | |
Member # 1635
One way to find out...
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
Member # 17313
well, they take alot of money to bring them up to the specs of a 14 bolt, 10.25, or dana 70.
as for price, I wouldn't pay more than $50-100 for any rearend, especialy a rear 60
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
What size are the shafts in a 14 bolt...not spline, but diameter?
I always considered the 14bolt to be in the same strength class as the Dana 60. What specific components are stronger?
Just go... Passionately centerist. We're slowly being killed by the far left and far right. Last edited by NOTPRETTY; 12-08-2004 at 10:05 AM. |
#10 (permalink) | |
Member # 17313
the shaft size is 1.5" just like a 10.25, and 70
A 35 spline ford f250 1979 diff has 1.5" shafts too. Anything else? I do believe the F250 1979 dana 60 is pretty good. Single wheel...etc I could be wrong though.
Also, I thought that most Corp 14 were 30 spline...yes some were 35, but most 30?
Just go... Passionately centerist. We're slowly being killed by the far left and far right. Last edited by NOTPRETTY; 12-08-2004 at 11:56 AM. |
#12 (permalink) |
Member # 29565
All 14 bolts to my knowledge are 30 spline.
Nearly all Ford rear D60's have 1.31" axle shafts, and are 30 spline. I had an older 16 spline pair of axles in the one I used to run...before upgrading to a 70. The D70, Sterling 10.25", and the 14 Bolt are all in the same ballpark in regards to strength. These are all true "One ton rear ends." To keep it simple, think of a D60 as a 3/4 ton rear axle. Yes, some Dodge's used 60's in the rear of one ton trucks, but they simply aren't as beefy as the 70, 14B, and 10.25". 35 spline Dana 60's (with 1.5" axle shafts) do exist but the vast majority of 60's were 30 spline.
1978 Big Ugly FORD F-350 460, C-6, NP 205, 4.10, 1410 DS Joints D60: Detroit, Dedenbear Knuckles, Yukon 4340 35 spline inners & outers, Longfield Superjoints, Drive Flanges Dana 70-U: Welded 4 Wheel Disc Brakes MM 12K Electric Winch Dual Batteries, A-6 OBA No Lift, 42" TSL's on 15x8's |
#13 (permalink) | ||
This is taken from the 14 bolt tech article. Quote:
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home. |
#14 (permalink) |
Okay...Can anyone confirm that a 78-79 F250 Dana 60 rear axle has 1.5" diameter shafts? Come on....Some has to know. I thought they were all 35 spline, but could be wrong.
#16 (permalink) | |
:laughing: |
#17 (permalink) |
Hmmm.......dana rear 60's not tuff ? I'm running 700 HP w/60's and NEVER broke a drivetrain part..........yet the same motor in another f-350 I have with a 60/70 combo broke constantly for 5 years...........how the piece flexes makes all the diffrence in the world.
1 is a 4 link truck, the other is leaf sprung........ And Iam prolly the most brutal mo fo you have ever seen behind a wheel........
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT] [FONT="Arial Black"]Current vehicles[/FONT] 67 Bronco 69 Bronco 81 Bronco 81 Bronco 75 F-250 (highboy) 77 F150 78 F150 70 F100 (2wd) 93 F350 95 F350 (Blown Crazy") 95 F350 ("Crazy Too") 87 Ranger (2wd) 00 Excursion 04 Navigator |
#18 (permalink) | |
14 bolt shafts neck down.
#19 (permalink) |
Member # 10385
According to ARB's list of applications, some 30/3500 series chevy's (1975-86) and some ford 350's both e and f (1988 on) had 35 spline 1.5" diameter shafts. All others, including 1975-'84 f250's had only 30 spline.
My girlfriend said if I spent one more dime on my Jeep she would leave. Man I'm going to miss her! |
#20 (permalink) |
yeah, the axle under the chevy you mention is a D70HD found in dually pickups, it has 1.5" 35 spline shafts. I am confused on the Fords listing, because some of the F250's came with D70s that would also be 35 spline. I am guessing ARB just doesn't have their shit down.
:laughing: |
#21 (permalink) | |
Well Done Man!
Yup, Tons of people snap Stock 30 spline 60 rear shafts like toothpicks
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
#22 (permalink) |
Member # 1136
Some 60 rears came with 35 slpine axles. And if not you can put 35 slpine D70 axles in a 60 with some work. Some 60s had the bigger spindles so the 35 slpline shafts would fit but if not you can bore them so they will fit and get a 35 spline locker and you have the clearance og a 60 adn the shaft strength of a 70 or 14B.
Toddy
IROCWEL |
#23 (permalink) | |
Banned
Member # 38228
#25 (permalink) |
I agree...anyone reading this thread would leave way more confused. Fact is...I don't think anyone here has a clue. I sure wouldn't trust anyone and go buy something.
Nuts and bolts: What vehicles could you get a Dana 60 35 spline rear axle in? I am talking about FORD, CHEVY, DODGE...whatever. Year make and model.
