2wd to 4wd conversion ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-27-2001, 10:28 AM   #1 (permalink)
MKBruin's Avatar
Member # 6407
Post 2wd to 4wd conversion ?
I have a friend with a 1993 f-150 2wd, what parts should I go for to convert to 4wd? Was ford using ifs then or is a solid front from an earlier fullsize bronco a direct bolt on?
______________________________
"Did you think this forum served a legitimate socially redeeming function other than mental masturbation?" posted by Bobzooki
MKBruin is offline   Reply With Quote Quick reply to this message
Old 08-27-2001, 12:13 PM   #2 (permalink)
Member # 929
Post
The cheapest way to do it is to buy a four wheel drive truck.
Gordon is offline   Reply With Quote Quick reply to this message
Old 08-27-2001, 01:32 PM   #3 (permalink)
MKBruin's Avatar
Member # 6407
Post
is that your way of telling me that it is NOT a bolt up procedure? I have a great supplier where I can get parts for next to nothing....but I will only do the job if it is a straight bolt up procedure. What parts should I pull from bronco's or f-150's? What years are best? I want this as straighforeward as possible, and yuor answer really didn't say much. thanks though... <IMG SRC="smilies/rolleyes.gif" border="0">
Old 08-27-2001, 01:41 PM   #4 (permalink)
Member # 3322
Post
Don't know bout these new ones (to me 93 is new) but on mine the 2wd didn't have a front crossmember. I'm sure these new ones have different frames as well.
67 VW bug
72 Ford F-100 4X4
67FLAT4 is offline   Reply With Quote Quick reply to this message
Old 08-27-2001, 01:49 PM   #5 (permalink)
Member # 2743
Post
I vaguely remember reading an article a few years ago about converting a 9? 2wd Ford Lighting to 4wd (I think it was in Peterson's 4W&OR).
bwright is offline   Reply With Quote Quick reply to this message
Old 08-27-2001, 06:25 PM   #6 (permalink)
Member # 4176
Post
Are the 4wd ver. Box frame or C Channel? Because my 89 2wd Ford truck is C channel. That may cause problems, i dont know.
StoopidMonkey is offline   Reply With Quote Quick reply to this message
Old 08-27-2001, 06:34 PM   #7 (permalink)
Member # 2743
Post
I believe the frames are the same, at least I know they are both C channel and not boxed.
Old 08-27-2001, 06:42 PM   #8 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
Post
Originally posted by mkbruin:
<STRONG>I have a friend with a 1993 f-150 2wd, what parts should I go for to convert to 4wd? Was ford using ifs then or is a solid front from an earlier fullsize bronco a direct bolt on?</STRONG>
my bro just converted his 88 F150 to solid axle, from IFS 4x4, which is basically the same as doing the 4x4 conversion. He used a front end, radius arms, coil springs, steering linkage, and track bar from a 78 bronco, 5.5" superlift springs for a late 70's F150, and a little ingenuity.
He had to fab the top half of the track bar bracket that attaches the track bar to the frame, the coils fit into the stock buckets, the rear shock of the factory dual shocks mounted to the stock shock location on the 78 hardware, the steering linkage bolted to the F150 pitman arm, and the stock radius arm crossmember was removed and relocated back far enough to accept the Bronco radius arms. Seems like your 4x4 stuff would be the same, except you might want to add a dropped pitman arm.
Difference is you will have to either convert the tranny to a 4x4 tranny (either my modifying the 4x2 tranny, or replacing it) or add a divorce mounted transfer case, which would probably be easier.
Hope this helps
Foley
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote Quick reply to this message
Old 08-30-2001, 09:09 PM   #9 (permalink)
Member # 4073
Post
For the 2wd 80-96 F-150's and F-250's, it's a bolt-in swap to go from 2wd to 4wd. Basically it involves replacing the beams with the 4x4 axle halves, replacing the tranny with a 4x4 version along with adding a t-case (tranny crossmember is the same), and adding/modifying the driveshafts to fit. A manual t-case would be an easier swap than the electric, just need to cut a hole in the floor for the shifter. Make sure the 4x4 axle halves you put in has the same gearing as your existing rear axle.
Dustin S.
I had a brain-eating disease that died of starvation.
Dustball is offline   Reply With Quote Quick reply to this message
Old 10-16-2001, 01:42 AM   #10 (permalink)
Member # 7600
Post
I was thinking of doing the same to my 94 crew cab. Need to find a 44 or 60 with a 8 bolt pattern first.
jeeps with stuff
wild1 is offline   Reply With Quote Quick reply to this message
Old 09-26-2010, 08:53 PM   #11 (permalink)
Member # 169624
I have a 93 f150 2wd and am Wanting to convert also seeming as how I don't have 7 or 8k to spend on a good 4x4 used truck, and I'm sure the junker I'm looking into getting for parts has IFS 4x4 and Was wondering if it would be about the same as a straight axle to install or would it be worse? I just got all new coil springs and buckets for them kinda wanna keep them in the whole idea but i don't know.
1993f150 is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 06:50 AM   #12 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The TTB is a bolt in swap, can do it in a few hours, no mounting of the suspension changes at all. No custom fab, nothing, I'm talking direct bolt in.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 08:11 AM   #13 (permalink)
broncdawg's Avatar
Member # 42245
The TTB system may be bolt in, but a straight axle conversion certainly isn't.
Many different threads on this can be found here.
77' Bronco,5.0 roller,Klune 4:1,37s,Wristed radius arm / 85' Runner-5.29s,Detroits / 79 F350 4x4
broncdawg is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 08:51 AM   #14 (permalink)
Member # 81828
divorced 205, wouldn't be bolt up, but its doable and your able to keep your tranny if its functioning well.
ptowntj is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 11:39 AM   #15 (permalink)
Member # 169624
I feel dumb but what is a TTB?
Old 09-27-2010, 12:10 PM   #16 (permalink)
Member # 163263
TTB stands for twin traction beam which is the factory 4wd front end for this era of truck all you would have to do is find a 4wd truck and pull the components out of it and put in yours such as the steering, suspension and differential along with the transmission and transfercase if you are wanting to keep the stock stuff. I didnt see a point in wasting the time to go that route so I extended my radius arms 16 inches and used joints on the end with custom mounts and built my own steering etc I am not done with all the little stuff like brake lines and drivelines yet but clear 35s on my truck which started out the same as yours a 93 2wd f150 so its easily doable. Here is a pretty good example of a build I used for references on some things. http://www.f150online.com/forums/pre...150-sas-3.html
01 TJ A bunch of parts
Midwest Ford Wheeler is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 05:23 PM   #17 (permalink)
Member # 168439
way to revive a 9 year old thread lol
1995 F-150 XL - 300 I6/M5OD-R2 2WD - Tow Pig
Flint, Michigan
sufferingant is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 09:05 PM   #18 (permalink)
Member # 169624
HaHa your welcome,
Old 09-27-2010, 09:07 PM   #19 (permalink)
Member # 169624
Would a Ford Explorer's front axle work under a f-150 or are they 2 different axles?
Old 09-28-2010, 11:25 AM   #20 (permalink)
Member # 163263
No an explorer axle wont work they are a smaller axle either a 30 or 35 and are to narrow to fit the f150. You can use a bronco axle though
