are ttb hubs the same as solid axle hubs? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-08-2002, 10:34 PM   #1 (permalink)
Member # 3976
Send a message via ICQ to CJ5-Man Send a message via AIM to CJ5-Man
are the hubs on a ttb d44 the same as a solid axle d44?
I'm going junkyarding tomorrow to get some hubs to convert my waggy 44 to 5 on 5.5 bolt pattern and in the past all I've seen are TTB equipped trucks. Oh, and I'm talking about the wheel hub, NOT the lockout hubs, and the search showed nothing.
EDIT: redid my search and found one post where someone said they are the same, just leaving this here for someone to possibly confirm this?
a bunch of mid 90's discoveries
CJ5-Man is offline   Reply With Quote
Old 02-08-2002, 11:05 PM   #2 (permalink)
Member # 7340
Yes they are the same...
[COLOR=BLACK] You picked a fine time to leave me loose wheel [/COLOR]
Chad H is offline   Reply With Quote
Old 02-10-2002, 03:42 PM   #3 (permalink)
Member # 6350
almost all
Almost all are the same, early 87, 88 will have the flange hub. Dealer only item.. But you'll know it when you see, no way to mistake it for anything but the paper weight it is.
Edit: IMANIDGET... I posted the wrong years, as was pointed out by welndmn (thanks) It is now correct.
[url="http://www.bronco78.com"]bronco78.com[/url]
[url="http://www.superford.org/registry/?vID=144"]Bronco Specs[/url]
[url="http://www.teamalaska4x4.com"] Team Alaska[/url]
[url="http://www.outbackchallenge.com"]Australian Outback Challenge
[/url]
bronco78 is offline   Reply With Quote
Old 02-11-2002, 11:05 AM   #4 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Re: almost all
Originally posted by bronco78
Almost all are the same, early 82, 83 will have the flange hub. Dealer only item.. But you'll know it when you see, no way to mistake it for anything but the paper weight it is.
did not know about the 83's are you sure? teh 87-88 had teh ford Hat style that is $$$$
Mark
welndmn is offline   Reply With Quote
Old 02-11-2002, 01:14 PM   #5 (permalink)
Member # 6350
Re: Re: almost all
mumm,eernmnnnpuhhhh.
POP.
Whew, thats better, it was getting stuffy up there.
Sir you are correct..
I was dealing with another parts issue that day, got my parts and years wrong....
By the book, MY 88 Broncos had flange style hubs,, But in reality, the shop in question, and fellow Bronco owners have found them on some MY 87's also. Local Ford dealer gets $387 for um,, Can you say, SWAP.
Thanks for the catch welndmn
[/url]
Old 02-11-2002, 03:37 PM   #6 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
, yeah, when one of those on my 88 went BAM! i search a ton of wreckers for it because i did not want to pay the high prices from ford
Mark
