Member # 9152
Do you know what year of early bronco this knuckle is? I think a couple years were D30 front, and even that knuckle might fit but you couldn't fit a D44 stub shaft in it. Then there's the drum brake D44 knuckles with 6 holes for the spindle. They fit, I'm sure Mr.N could nail it down for you with specifics if he got that D60 out of that pickup bed.
Why kill them with kindness when you can use an axe? |
#4 (permalink) | |
Member # 9152
Member # 25609
early bronco D44 knuckles will fit and you can use the same outer shafts.
The D30 will not fit and hp44 axle I swapped in 79 bronco D44 knuckles onto my early bronco D44 for disk brakes
74 Bronco,302,C4,dana20,twin sticked,1350 shafts, D44,4.88,spool, w/warn shafts&CTM's,9",4.88,spool, superior shafts,38.5x15 boggersw/beadlocks, JBG 5.5" superflex susp.Extended arms,Ram Assist, Durabak inside n out [URL="http://www.supermotors.org/vehicles/registry/detail.php?id=4052"]http://www.supermotors.org/vehicles/registry/detail.php?id=4052[/URL] |
#6 (permalink) | |
Member # 17313
I thought they used 6 hole knuckles, which is why you can use small bearing chevy spindles for a cheap disc conversion on them?
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Early Bronco drum brake spindles are 6 bolt and early Bronc disc brake spindles are 5 bolt either will interchange with hp 44 as long as its eb44 not eb30
keep up or get left behind 75 bronco trail buggy 60-9 frt build up thread OutBack Auto 4WD and Fab MV4W.com |
