factory posi?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2005, 11:21 AM   #1 (permalink)
waverider's Avatar
Member # 11971
factory posi??
I'm not a Ford guy and I'm trying to find out what this carrier is. Is it a factory limited slip? I found one web page that called it a posi? is there such a thing as a factory posi for the 8.8?
[URL=http://www.lucky13offroad.com]LUCKY 13 OFF ROAD[/URL]
waverider is offline   Reply With Quote
Old 02-06-2005, 11:25 AM   #2 (permalink)
Member # 41147
thats the factory limited slip for an 8.8.
i dont need people to get me,i just need people to get out of my way.
st ranger is offline   Reply With Quote
Old 02-06-2005, 11:48 AM   #3 (permalink)
waverider's Avatar
Member # 11971
Besides pulling the axle shafts, how do I find out if this 8.8 has 31 spline shafts?
Old 02-06-2005, 12:04 PM   #4 (permalink)
Member # 41147
if you know its origins,you will know.
all fullsize trucks and explorers had 31,rangers and cars had 28.
Old 02-06-2005, 12:32 PM   #5 (permalink)
waverider's Avatar
Member # 11971
That's the problem, I don't know what it came out of. I found it in a scrap metal bin.
Old 02-07-2005, 12:58 PM   #6 (permalink)
Member # 41147
ok,if its 5 on 5.5 lug pattern,its 31
if its 5 on 4.5 with leaf mounts on the bottom of the tube and no shock mounts,it might be explorer(31)or a leaf spring car(28).
if it has 4-link mounts,its from a car(28),and if it has 5on 4.5 with leaf mounts on top and shock mounts,its from a ranger(28)
Old 02-07-2005, 01:40 PM   #7 (permalink)
Member # 17347
why not just count the splines inside the carrier?
71.5 Bronco Wagon
1976 F100 giant pile of parts, that is finaly a roller...
CHOPPEDBII is offline   Reply With Quote
Old 02-07-2005, 02:04 PM   #8 (permalink)
Member # 41147
that would be too easy
Old 02-07-2005, 02:09 PM   #9 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
Mustang Cobra's had 31 spline shafts too........pretty unlikely you'll find one in the scrap bin tho
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote
Old 02-07-2005, 02:18 PM   #10 (permalink)
Member # 19718
that's a trac-loc, they can be made to perform better by rearranging the order of the clutch discs/spacers.......count the splines on the inside of the side gears
I have the biggest pile of dead cats in McClain County
snyyyper is offline   Reply With Quote
Old 02-07-2005, 03:48 PM   #11 (permalink)
Member # 34262
Send a message via Yahoo to collinsperformance
i am sure that is just a factory open rear end with the LS spring in the center. the traction loc diff had a slot 1"X1" square cut out so the pins on the clutches would hold. I do not see and clutches in the diff. i can not post here but i got pics of the ford traction loc that was in my bronco.
mike
collinsperformance is offline   Reply With Quote
Old 02-08-2005, 05:55 AM   #12 (permalink)
Member # 41147
the big notch is on the other side.you can just see the smaller notch in that picture that the clutch discs lock into.
