How to change vin numbers legally? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2005, 12:31 PM   #1 (permalink)
Member # 44704
Here's the situation:
I have 2 trucks, a 74 F-100 4x4 and a 79 Bronco. I'd like to combine the two non-working trucks and make one running truck. I'd like to keep the bronco body, but want to keep the truck registered as a 74. Any tips or suggestions?
Fishin' Dave is offline   Reply With Quote Quick reply to this message
Old 03-21-2005, 02:50 PM   #2 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I don't think you can legally do it. It wouldn't be a problem if you registered it as a 79 Bronco.
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 03-21-2005, 05:02 PM   #3 (permalink)
austynn2001's Avatar
Member # 27587
Send a message via AIM to austynn2001
around here, we would do the truck combo thing and register it as what you want (74 F-100 in this case) and leave it be. The cops around here wouldn't care what it was registered as if you told them what you did and how old it is. Don't know how your police force is, but it would be fine here.
1998 Green Impreza Wagon-1988.5 Samurai TT-1998 Samurai w/ stuff-8? Samurai-96 F250 7.3 w/ stuff
austynn2001 is offline   Reply With Quote Quick reply to this message
Old 03-21-2005, 05:58 PM   #4 (permalink)
Member # 39679
Send a message via AIM to Skedar2
Unless the cop new that a 74 bronco looks absolutely nothing like a 79 bronco, this might raise suspicions and give him a good reason to get an inspection ordered.
1977 F-250 Highboy, 429 dove-c heads ported polished with large valve job, L@L headers, 6 " suspension 2", 42 " swampers, 205 divorced t-case, C-6, 60's front and rear (rear detroit, powrlok front), 4.56 gears
Skedar2 is offline   Reply With Quote Quick reply to this message
Old 03-26-2005, 10:10 PM   #5 (permalink)
Member # 13340
If you have the title for both it's not a problem. Here you just take the combined vehicle to State Patrol for inspection with both titles and receipts and they'll make it to the frame and motor. Tell them the frame and motor are from the 74. Been there done that
Skip
I used to be open minded, but my brains kept falling out.
Skip
sfrans is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 07:27 AM   #6 (permalink)
3vze's Avatar
Member # 13561
Sfrans is right, here anyway. I swapped out a dash. The ones that have vin plates and they took the old plate off and switched it for me. They told me to do the same thing if I were to do that with a body or a frame. Just keep all your recipts/BOS.
3vze is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 05:15 PM   #7 (permalink)
Member # 44549
what about cats
you may want to check and see but in my experiences the 79 would require catalytic converters where usually the 74 wouldn't. just thought i would throw this out there. the state may require you to run cats even though you are running a 74 registration
stillbuggy is offline   Reply With Quote Quick reply to this message
Old 04-27-2005, 04:45 PM   #8 (permalink)
Member # 25481
Dave,
In California, they go off the stamp in the frame (I believe it's on the passenger's side near the footwell). I have a '79 frame under my '73 F100. I kept it registered as a '73, but I found out it wasn't legal.
If you want to stay legal (atleast in CA), you'll have to chop the F100 frame and put it under the Bronco and have it inspected by the Highway Patrol.
1973 F100 4wd
http://www.ATV-Racing.com
fishbulb is offline   Reply With Quote Quick reply to this message
Old 04-27-2005, 04:57 PM   #9 (permalink)
Member # 25481
I do need to be honest about one thing. I got in an accident with the truck, and I was worried that I'd get found out. Neither the police or the insurance company realized that it said "1973 2wd F100 Longbed" on paper, but they were looking at a 1979 4wd Shortbed. When I took it back to the DMV for re-inspection, the DMV inspecter didn't catch it either. So you might be safe.
1973 F100 4wd
Old 04-28-2005, 07:06 AM   #10 (permalink)
Member # 11612
Local dude huh?
If you have Nazi DMV (Cali,Oregon, ect) then you may have an issue with emmisions. Here in NC, or at least the smart ones who keep them registered in a different countu , there isnt much inspecting. Hell I have filled out my own inspection for years.
[COLOR=DarkGreen]94 Bronco EB- ZF 5SP, SAS ongoing[/COLOR]
[COLOR="DarkOrange"]Corley Body Works- RestoMods & Classic Restoration[/COLOR]
[COLOR=Red]Need Scout Parts?
[/COLOR]
Franklin is offline   Reply With Quote Quick reply to this message
Old 04-28-2005, 09:16 AM   #11 (permalink)
blown4x4's Avatar
Member # 43190
Originally Posted by Franklin
Local dude huh?
I live in oregon and never had any of my vehicles inspected Hell I have a 90 ford with a carbrated engine NO cats just straight 3 inch duals no problems
blown4x4 is offline   Reply With Quote Quick reply to this message
