Has anyone ever tried this or heard of it? Ford Ignition Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-20-2005, 09:48 PM   #1 (permalink)
Member # 46374
On my 87 F-150 I swapped the blown In-line 6 for a 302, I have a 70's model MEXICO block, bored 40 over, flat top pistons with valve reliefs, a flat tappet cam and around a 90' model set of mustang heads that have been mildly worked, my problem lies in a miss that starts in mid RPM range and increases with RPM's. My ignition set up is still where i'm thinking the problem might be, here is how i've got it set up: After removing the in-line 6, i saved the plugin for the side mounted module type distributor, and after installing the 302, I just dropped in a late 80's model side mounted module type distrubtor and plugged it up, and used the Tower type coil that goes with this factory setup. When i first tried to get the engine cranked, it would hit but wouldn't start, after messing with it a bit, i tried removing the in-line spout connector, just to see if it would have anything to do with it, and wa lah it started and timing was able to be set with a timing light. I still had the 6 cyl. computer in the truck, until just recently I swapped that, but to no avil. The miss is still there, and all other problems have been ruled out, plugs, wires, cap, rotor, and coil. I haven't tried another distributor, does anyone have any ideas? I'm also running a four barrell and just the common neccesity hook ups, nothing is hooked up for the computer, except the distributor, but it does still run excellent other than the miss.
5.0crazy is offline   Reply With Quote
Old 04-20-2005, 09:55 PM   #2 (permalink)
Member # 17313
efi ignition doesn't run to well with a carb...
try putting on durasparkII and be done with it.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 04-20-2005, 10:42 PM   #3 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Yup, you're not getting any advance wth the setup you have now. Swap it out to a DS-II distributor and be donw eith it.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
Old 04-20-2005, 11:09 PM   #4 (permalink)
Member # 46374
I've also looked at the cross breeding option that is described on Bronco.com website, and that is called a HomebrewHEI. It has the diagram to wire up a Common Chevy Module with any Duraspark! The only real issue mentioned is the module getting hot if not mounted to some type of heat desipating device, and i located a aluminum cooling type device that had a module bolted on it originally, so i may try this instead of having to worry about burning the old untrusty Ford brainboxes up.
Old 04-20-2005, 11:57 PM   #5 (permalink)
Member # 17313
just say no to HEI, dursparkII is miles ahead of HEI.
Look at any jacobs or MSD setup, reminds you alot of a durasparkII setup, doesn't it?
Old 04-21-2005, 07:51 AM   #6 (permalink)
BUZZISCRAZY2's Avatar
Member # 17399
Send a message via AIM to BUZZISCRAZY2 Send a message via Yahoo to BUZZISCRAZY2
The duraspark is good for 10,000 RPM all day, try that in a HEI !!
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT]
[FONT="Arial Black"]Current vehicles[/FONT]
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
95 F350 (Blown Crazy")
95 F350 ("Crazy Too")
87 Ranger (2wd)
00 Excursion
04 Navigator
BUZZISCRAZY2 is offline   Reply With Quote
Old 04-21-2005, 10:01 AM   #7 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
The "old untrustworthy brainboxes" that fail often are usually aftermarket ones. I've never had a Ford one go bad yet, the one on my 460 is on it's 5th engine, 3rd vehicle... Now that I said that, it'll die tomorrow... LOL
As for using the HEI module with a DS-II distributor, that should work just fine, Haven't tried it myself yet though.
Old 04-21-2005, 10:10 AM   #8 (permalink)
Member # 17399
Wells
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
87 Ranger (2wd)
00 Excursion
04 Navigator
Old 04-21-2005, 06:42 PM   #9 (permalink)
Member # 46374
I'll agree probably all i've had to fail were probably aftermarket, also the thing we had on the V8 Ranger was, if you left the switch on for any amount of time, it would burn the box up. I have found different wiring diagrams since then, that should eliminate that issue though.
