Camshaft decision - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2001, 07:54 PM   #1 (permalink)
Member # 2331
Post Camshaft decision
I am rebuilding a basically stock 302 for my 1990 F150. I want a little more torque from the motor than stock, but it doesn't have to be a monstrous increase. Can anybody help me out here?
302
EFI
AOD tranny
3.55 gears (changed to 4.10's at a later date)
31" tires.
Warlock is offline   Reply With Quote
Old 09-22-2001, 10:05 PM   #2 (permalink)
Member # 6139
Post
When I redid my '73 302, my builder I wanted more torque. My builder recommended a Schneider cam. It may be the same one that K bar S (Bronco specialty house) sells. The motor seems to run very strong.
73EB is offline   Reply With Quote
Old 09-23-2001, 05:16 PM   #3 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Lightbulb
Here is a Desktop Dyno simulation of the engine that I had built for my Mustang way back in the summer of 1992. It's basically bored 0.030, a little bit of exhaust port work, planed heads, 600cfm vac sec Holley, shorty headers and a Comp Cams 270 Magnum (224 @ .050 with .500 lift) and approx 10.5:1 compression. It has a pretty nice flat torque curve but I really don't know, this combo might be a little too much for off road use but then again it might be perfect.
[ 09-23-2001: Message edited by: Paul Gagnon ]
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote
Old 09-23-2001, 06:08 PM   #4 (permalink)
Member # 3306
Post
When I freshened up my 351w, I put an RV cam in. I am not sure of the specs. It was from PAW mail order, their house brand. I works very well. I am happy with it.
[ 09-23-2001: Message edited by: Push Rod ]
SO WHAT
Push Rod is offline   Reply With Quote
Old 09-23-2001, 06:53 PM   #5 (permalink)
Member # 2657
Post
Split pattern cam - more lift on exaust side - SB Fords need help on the exaust side.
Stay away from lots of duration - Headers will help A Bunch.
Luck
Merlin <IMG SRC="smilies/biggrin.gif" border="0">
Daddy said "Experience is a hard school but the only one a fool can learn in"
Merlin is offline   Reply With Quote
Old 09-24-2001, 07:25 PM   #6 (permalink)
Member # 4068
Send a message via ICQ to TX4WHEELER
Post
I have had good luck with the Comp cams Extreme 4X4 series cams in my 4X4's. There are 3 or 4 different grinds.
Robert Hutson (TX4Wheeler)
1978 Ford Bronco
460, C-6, D60 Front with ARB and 35 spline outers, D70 rear, disk brakes, welded diff,7" lift, 38.5X14.50 TSL/SX's, Warn 8274 winch, Hydro Assist steering
TX4WHEELER is offline   Reply With Quote
Old 09-24-2001, 07:36 PM   #7 (permalink)
Team RedNeck
TheLakeRat's Avatar
Member # 3941
Send a message via AIM to TheLakeRat
Post
What you need to do is just weld on the top of the lobes a little. That will make your little rocker thingies move up and down a little faster. I did it to mine and I gained at least 200 more HP. <IMG SRC="smilies/rasta.gif" border="0"> <IMG SRC="smilies/innocent.gif" border="0">
Hey Rob, how's the D60R swap going?
Sorry to butt in. Just couln't help myself.
Matt Hodges, Owner
West Texas 4Wheel & Offroad
325-653-7001
1811 W. Beauregard Ave.
San Angelo, TX. 76901
www.westtexasoffroad.com
Redneck is not a style, fashion, or something that occurs due to location – It’s way of life. You can’t be one - either You Are or You Aren’t. I AM.~SilverZuk
TheLakeRat is offline   Reply With Quote
