Member # 27187
lost power with my new set up
5.0 mustang motor C6 to 205 4.88 in axles 40" MTR since install the engine just bogs down when up against an obstacle. Any hints on how to cure this problem?
Member # 26750
Not enough gear and maybe torque convertor too low a stall . A c6 will eat about 20hp more than a c4 . At least 1700 is nice in a rockcrawler and maybe more if you dont do gears. Spend it now or spend it later ,
Lou EB Buggy #231 RCrocks/Line Mtn www.EXTREMEAXLESALES.COM WWW.INTERCOTIRE.COM WWW.RC4X4.ORG WWW.earlybroncos.com www.stickeylee.com www.bilstein.com |
What was the motor before it ? Is the new 5.0 stock ?
What vehicle and weight?
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT] [FONT="Arial Black"]Current vehicles[/FONT] 67 Bronco 69 Bronco 81 Bronco 81 Bronco 75 F-250 (highboy) 77 F150 78 F150 70 F100 (2wd) 93 F350 95 F350 (Blown Crazy") 95 F350 ("Crazy Too") 87 Ranger (2wd) 00 Excursion 04 Navigator |
Member # 27187
I have good oil pressure and this is the stock 93 5.0. I had this motor in with a 435 dana 20 with 4.11 gears and had power to spare. Now I can't even roll up onto my trailer. I had the tranny built with the lowest planetary gears and rebuilt the 205. ????? could it be I'm not geared low enough with the 205? Thanks for your help
Member # 62
how is the power once you get the tires moving? If its just lacking off the line power but has good power when rolling or if you break the tires loose I would say a looser torque converter will help alot.
Any idea of the specs on your current converter? your gearing is less then great but should be able to get around better then what your describing.
Jeff Neves |
Member # 25927
Sounds like something is wrong in the trans. The tires are a little big for 4.88's and a small block. Have you ran codes on the engine? Might be something simple like a clogged fuel filter.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here Dana 60 front 3/4 ton kits $350--> click here |
#10 (permalink) | |
