Where to buy 9 inch hardware? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-24-2005, 07:23 PM   #1 (permalink)
Member # 27315
I need the knurled studs that press into the housing for the center section along with the nuts and washers. I've checked Summit, Jegs, Randy's ring and pinion, the local speed shop, the local gear/diff shop.....nobody has any. Is there a place that sells this hardware besides the dealer?
uglyredjeep is offline   Reply With Quote Quick reply to this message
Old 05-24-2005, 10:13 PM   #2 (permalink)
Member # 25325
Send a message via AIM to redranger4.0
broncograveyard.com
redranger4.0 is offline   Reply With Quote Quick reply to this message
Old 05-24-2005, 11:36 PM   #3 (permalink)
Member # 27315
You know what, I almost checked there and for some reason didn't. Just placed my order. Thanks.
Old 05-25-2005, 08:31 AM   #4 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
If for some reason, JBG cancels your order because its not stocked............ here
http://www.strangeengineering.net/
Mark
Old 05-25-2005, 09:52 PM   #5 (permalink)
GrandZJ's Avatar
Member # 13785
Send a message via AIM to GrandZJ
www.completeoffroad.com
GrandZJ is offline   Reply With Quote Quick reply to this message
Old 05-26-2005, 11:12 PM   #6 (permalink)
Member # 14600
Here you go: http://www.mittlerbros.com/rearend_parts_acc.htm ..........Hans
Just a redneck trapped in a brown man's body
Oatmeal is offline   Reply With Quote Quick reply to this message
Old 05-27-2005, 08:37 AM   #7 (permalink)
Member # 595
You might just try the stealership. Also Moser should have the stuff.
1967 Bronco for sale $13,000 in classifieds
Injected 5L, Dana 60, ARB, Swampers, Hydroboost
EBSTEVE is offline   Reply With Quote Quick reply to this message
