Dana 60 ????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-31-2001, 12:15 PM   #1 (permalink)
Member # 4380
Post Dana 60 ?????
Ok guys, please help out an uneducated rice burner. I am looking for a dana 60 front, driverside 3rd. ie FORD. My question to you is what did these come in, what years are high pinion, what years are kingpin vs balljoint, and what years are TTB?
Thanks in advance
It's Not what you buy it's what you BUILD!!!!
Rokrunner is offline   Reply With Quote
Old 08-31-2001, 02:49 PM   #2 (permalink)
Member # 2139
Send a message via Yahoo to FordPowr
Post
78/79 and 86-97 were Reverse cut, in 78/79 they came in someF250's and all F350's. In 86-97 they only came in F350's.
I beleive they were kingpin up until 92' then they switched to balljoint.
they never madea D60 TTB...only 44 and 50
FordPowr is offline   Reply With Quote
Old 08-31-2001, 03:45 PM   #3 (permalink)
Member # 3600
Send a message via AIM to Tx Outlaw
Post
Originally posted by FordPowr:
<STRONG>78/79 and 86-97 were Reverse cut, in 78/79 they came in someF250's and all F350's. In 86-97 they only came in F350's.
they never madea D60 TTB...only 44 and 50</STRONG>
Which is stronger...... king-pin or ball-joint?
'99 TJ - mine, '01 PSD CC 4x4 - hers, '05 FLSTCI - [COLOR=Red]MINE!![/COLOR]
Tx Outlaw is offline   Reply With Quote
Old 08-31-2001, 09:00 PM   #4 (permalink)
FearMe's Avatar
Member # 1565
Post
I'd say kingpin.
I've outlived my dick.
FearMe is offline   Reply With Quote
Old 09-02-2001, 11:17 PM   #5 (permalink)
Member # 2139
Post
The only real advantage with kingpins I can see for our application is it's much easier to install high steer arms on then. On the balljoint knuckles you have to machine the knuckle a bit to accept the arms.
Old 09-03-2001, 12:16 PM   #6 (permalink)
Member # 4380
Post
Thanks I appreciate all the help that is exactly what I was looking for.
Old 09-04-2001, 01:43 PM   #7 (permalink)
Member # 5551
Post
One more thing you might want to consider...
The 78/79 were leaf sprung and the newer ones were coil sprung.
MaxCrack is offline   Reply With Quote
Old 09-04-2001, 01:45 PM   #8 (permalink)
Member # 2139
Post
Originally posted by MaxCrack:
<STRONG>One more thing you might want to consider...
The 78/79 were leaf sprung and the newer ones were coil sprung.</STRONG>
All the Ford D60's were leaf sprung
Old 09-05-2001, 07:49 PM   #9 (permalink)
Member # 4068
Send a message via ICQ to TX4WHEELER
Post
[/QUOTE]One more thing you might want to consider...[QUOTE]
You must be thinking about the TTB F-250 and F-350. They had coils. All Ford D60 fronts were leafs
Robert Hutson (TX4Wheeler)
1978 Ford Bronco
460, C-6, D60 Front with ARB and 35 spline outers, D70 rear, disk brakes, welded diff,7" lift, 38.5X14.50 TSL/SX's, Warn 8274 winch, Hydro Assist steering
TX4WHEELER is offline   Reply With Quote
Old 09-07-2001, 12:57 PM   #10 (permalink)
Member # 497
Send a message via ICQ to wheelin'bitch Send a message via AIM to wheelin'bitch
Wink
Originally posted by Rokrunner:
<STRONG>Ok guys, please help out an uneducated rice burner. I am looking for a dana 60 front, driverside 3rd. ie FORD. My question to you is what did these come in, what years are high pinion, what years are kingpin vs balljoint, and what years are TTB?
Thanks in advance
</STRONG>
check my post...
[COLOR=Teal]nothing says naked like bluegrass[/COLOR]
wheelin'bitch is offline   Reply With Quote
Old 09-07-2001, 01:55 PM   #11 (permalink)
Member # 929
Post
Even the TTB F250 and 350's had leaves only the 150's had coils.
Gordon is offline   Reply With Quote
Old 06-13-2009, 03:41 PM   #12 (permalink)
Member # 137313
ball joints are good if your not running 40's, 44's, ect. and side loading them (driving sideways on hills washouts rock crawling, ect.) the only thing i liked better about balljoints was they are a hell of alot easier to change a ball joint as opposed to kingpins...lol
trail*ridin is offline   Reply With Quote
Old 06-13-2009, 06:00 PM   #13 (permalink)
Old Ford Guy
4XFORD's Avatar
Member # 27645
There is so much mis-information in this thread it should have stayed buried back in 2001, but thank you for your pearls of wisdom oh king of search.
Real trucks have the dimmer switch on the floor.
4XFORD is offline   Reply With Quote
