Member # 44753
wristed radius question
i am building a homemade radius set up for my ex on 404 mogs.
i was wondering if the trucks that have this,drive strange when not pinned? does it wear out the radius bushing on the non wristed side bad? thanks |
Member # 16545
just lotsa body roll when not pinned
iv'e got poly c-wedge bushings and have noticed no wear yet just a q i have not seen any pics of your setup but where on the 404 are you mounting the radius arms? i'd be worrid about bending arms with all the leverage on them
canadian gunnut |
Member # 44753
ya,i have a thread started on the mog board about that!i'm a little worried,but i have some real thick material to use,so i think it should be ok
any other idea's? ![]() by the way,the template i made up today for the diff mount has about 10" of seperation bettween the upper radius mount and the lower.that seems like alot,and i think it should help. Last edited by green meanie; 06-05-2005 at 09:45 PM. |
Driven by hate
made this out of 1.5" 0.25" wall with some 0.25" angle, bent that :dropkicknutz:
so i made this, 1.75" 0.375" wall with that big ol fawkin gusset bracket thing... bent that too ![]() I'm about ready to give up on the radius arm and turn it into a three link. I just have a old/stock v6, 120:1 with 42's on a "trail rig" prob in the mid 4k range.
You can check-out any time you like, But you can never leave! |
Member # 3113
I replied to your other thread. I went 3 link. My lowers are 2", 1/4 wall. My upper is 1.5, 1/4 wall sleeved with 2", 1/4 wall. So far, so good and I've hammered her a bit. See pics here.
http://ox.users.superford.org//UNIMO...pers%20needed/
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies 79 Bronc XLT, 400/C6/404 Mogs/42 roks |
#8 (permalink) | |
Member # 22026
I haven't seen any additional wear on any bushings on either side from before installing the wristed arm and with it.
69 Bronco, narrowed 8 ", locked F&R, Atlas, big tires, winch, blah, blah, blah... |
#9 (permalink) | |
OX how come your uppers are sleeved yet your lowers are not?
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home. |
#11 (permalink) | |
Member # 3113
#12 (permalink) | |
Member # 3113
#13 (permalink) | |
got it now. I missed that part. So why not thicker lowers?
#14 (permalink) |
Member # 16225
As for the wristed radius arm, i have been running one for a couple years and i am over it. I have alot of brake dive and jacking during acceleration. I would just build a 3 or 4 link to get better handling. My GF drove it once, and the first corner she hit, she had it nearly in the ditch on its lid. Mine is a handful on the street, and since i dont have a trailer, i am going with a link type suspension when i put in the front 60. Btw, your buildup is looking sweet
toyota crawler 1tonYJ project |
#15 (permalink) |
Member # 27153
I ran a wristed arm for about 3 years of hardcore beatings with 38's under an EB with a 44. Aside from not being able to get any brand of shaft to live , I spun the axle tube in the housing. Several people I know that ran D44 with wristed arm spun tubes as well after several years of hard use with big tires. The wristed side has NO torsional control and those big tires exert all that force to the tubes under hard breaking. This causes one side or the other (whichever gives first) to eventually spin. I trashed the wristed and went with a 4 link that uses the stock lower frame mount and bushing for the lower link and an inboard frame link for the top with a trac bar. Kept my rock crawler coils and it flex's better than the wristed and handling is now great.
K&K Racing #21 ECORS Class A Early Bronco |
#16 (permalink) |
Member # 44753
i am acually doing this to a mog diff in a 94 explorer,so the tubes ain't gonna spin!
but there is a ton of leverage,so that is probably not the best route to take. but i am trying to keep it as low as possible with a stock mog diff,and it is proving tough!i think i sould be able to make the 4 parallel links with a panhard work. does anyone have any good pics of how you mounted the upper inboarded links to the side of the frame? and i think i will go ahead and find some stock frame lower brackets and use the radius arm bushings for the lowers like broncman. i already got rid of the explorer brackets,so is there a better year than one another to look for?i would like to stick with the early bronco style bushings that have none of the plastic inserts like the ex one's had. |
#17 (permalink) | |
Member # 3113
#18 (permalink) | |
Member # 3113
To keep it low like you want, I had to go custom front housing to get the diff where ford put it. Also made a mini-truss around the diff and put forward end of upper as high as I could (since my lowers are so high due to stock steering). Carefull planning and it seats nicely between the frame and oil pan, but at full stuff, it does tag the motor mount perch, which I have since grinded out a bit. I am going to hog out the perch and reinforce it when I do a motor swap soon.
#20 (permalink) | |
Member # 3113
Here's a posin pic.........
#22 (permalink) | |
Well Done Man!
I ran one for many years, and love it, I too had heard of people spinning tubes with a wristed arm, but welding the tubes in fixes that. For the money nothing will beat a wristed arm.
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
#23 (permalink) | |
Member # 3113
