1990 Full Size Bronco
Quick ? how do i remove the Ignition key assymbley from the column do i have to remove the steering wheel and all that or can i be removed from the side? Thanks Will Kosonen
1983 Jeep J10 - BJ's 6 inch lift, MSD Offroad Box, 35 x 14.5 x 15 Boggers, Rancho RS9000xl Shocks with cab controler, 350HP Ford 289 1971 Ford Bronco - 302 3.5 James Duff Lift, My work in progress 1980 Jeep Wagoneer - Stock for now |
Member # 6398
If you just wanna pull the lock cylinder, insert the key, turn it on and depress the little button thru the small hole just under the cylinder. The cylinder will slide out.
"Take 300 people and on average 290 of them just generally suck at life" |
Banned
Member # 48208
i just did mine a while ago, and i got an aftermarket cylinder, and it took about 5 minutes to replace, but just dont listen to the instructions, just put the key in, turn it on, and then push the pin in and pull out, and to put it in u just put in the new key, turn the cylinder till, the pin goes in and put the cylinder in, and turn the ignition off.
The pin is in the little hole next to the hazard lights switch. |
Member # 49732
key cylinder
in a 90 model, you probably have to remove the steering wheel. then you have to push a pin that is hiding at an angle on the cylinder. i did mine this weekend, & i have a 91 custom. (no little holes in the column, dangit) oh yeah, get the motorcraft replacement part, its only 16 bucks!!!
