ZF transmission interchange ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2005, 01:33 PM   #1 (permalink)
3vze's Avatar
Member # 13561
Are the ZF trannys in the broncos the same as the F-series ?
TIA
3vze is offline   Reply With Quote
Old 08-19-2005, 02:01 PM   #2 (permalink)
300Puller's Avatar
Member # 35004
http://www.zf-group.com/pdf/S5-42.pdf#search='zf%20420'
http://www.zf-group.com/pdf/S5-47.pdf#search='zf%20470'
300Puller is offline   Reply With Quote
Old 08-19-2005, 02:45 PM   #3 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The ZF was only factory installed in F250's and bigger, there apparently are some F150's and Broncos out there with the ZF installed from the factory, but, they are few and far between. Anyhow, if the trans has the same bellhousing pattern, it's interchangable. Both 5 speeds that were offered in these trucks share the same dimensions, so, the small block version of the ZF and the M5OD are interchangable.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is online now   Reply With Quote
Old 08-19-2005, 03:31 PM   #4 (permalink)
Member # 17313
yep, no ZF's in bronco's.
If you get one from a F-250, along with all the accesories, it will bolt right in.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 08-22-2005, 10:35 AM   #5 (permalink)
3vze's Avatar
Member # 13561
For future reference and for the archives. The broncos do have ZF's
I picked one up this weekend from a 88 FSB.
