the case of the mysterious death wobble - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2005, 09:55 AM   #1 (permalink)
Andy351's Avatar
Member # 22290
Send a message via AIM to Andy351
so i went to fordyce over labor day weekend, drove the bronco (87 D60 front) there and back. put a hole in one of my iroks, but no big deal i drove home on a spare and it actually drove better on the way home. so i got home and parked the bronco and drove my super sweet jetta till i had to move. when it came time to move the bronco i drove it around and strangely it developed a nasty case of death wobble while sitting for a week and a half...i'm a little stumped since it was just sitting and now it has a problem. i'm in SLO now but i'll be making a rescue trip home to fix it and bring it down but i need some clues where to start.
things i have thought of:
- adding a steering stabilizer (i should have had one from the get go)
- adding a second washer to the kingpin springs (they pass the 12 and 6 jiggle test, they were rebuilt last summer)
- replace the bent tie rod end (was also loose, but tightening it didn't fix anything)
- checking the wheel bearings to see if one has seized while it was sitting (i doubt it because i repacked them less than a month ago)
- friends have mentioned flat spots, but this is real death wobble, not just bouncy tires (i've experienced both)
click the link in my sig to see the specs
www.PolyPerformance.com
WE GOT WHAT YOU NEED
When people in the Taliban are riding around in better trucks than you, you might have a problem.
Andy351 is offline   Reply With Quote
Old 09-20-2005, 11:34 AM   #2 (permalink)
Member # 6733
As far as quick fixes go, I'd try rotating the tires. Also repack and retorque the wheel bearings. I've had DW at least 3x that was due to nearly imperceptible slop in the wheelbearings. Or at least, tweaking the bearing preload changed the susp enough to make it go away.
Rotating the tires does the same thing -- slight change in mass, roundness, balance, etc will make the difference sometimes. It might not get to the root of the problem, but it can be enough to manage the DW, if not eliminate it.
If the bent tie rod affected your toe, fix that... but so long as the ends are tight, the bend shouldn't be causing any problems.
Team Fat Shit and the Traveling Circus
saf-t scissors is offline   Reply With Quote
Old 09-20-2005, 05:32 PM   #3 (permalink)
Member # 27153
tracbar?? Loose steering box??
K&K Racing #21
ECORS Class A Early Bronco
broncman is offline   Reply With Quote
Old 09-20-2005, 07:11 PM   #4 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
Originally Posted by broncman
tracbar??
leaf sprung 60
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote
Old 09-24-2005, 11:57 AM   #5 (permalink)
Andy351's Avatar
Member # 22290
fixed it, added a washer to the kingpins and tightened up the meshload on the steering box.
