429 help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2005, 05:33 PM   #1 (permalink)
1980Jimmy's Avatar
Member # 43687
429 help
Im not a ford guy but i picked up a 429 with dove heads. I need to know what the casting # mean. 9J30 Dove-C # on heads. What ive found on the block 8K24 and new pistons that need to be installed 8-L131of-030 and help would be nice thanks!
1980Jimmy is offline   Reply With Quote
Old 09-22-2005, 08:16 PM   #2 (permalink)
Member # 48732
Send a message via AIM to 70cyclone Send a message via Yahoo to 70cyclone
just give it to me and I will take care of it for ya
77 F150 new project 545/C6/205/rockwells/53s
79 Bronco (parting out)
85 Bronco 351W/C6/208(parting out)
01 F350 PSD 4x4
70 Mercury Cyclone Spoiler 429CJ/4sp
70 F250 crewcab shortbox
89 F350 4x4 460/ZF
93 Mark VIII 4.6 Cobra
66 Dart GT convertible
70cyclone is offline   Reply With Quote
Old 09-22-2005, 08:36 PM   #3 (permalink)
1980Jimmy's Avatar
Member # 43687
For a price! Any info on what Ive got?
Old 09-22-2005, 08:49 PM   #4 (permalink)
mj
Member # 1919
date codes
I am certain a google search will find that
http://www.fordification.com/FAQ-datecodes.htm
mj is offline   Reply With Quote
Old 09-22-2005, 09:29 PM   #5 (permalink)
Member # 21904
Originally Posted by mj
date codes
Heads are 1970. About 76cc and push right at 11:1 compression with flat tops. These heads were very common in the 460 Lincolns and Thunderbirds of 1970 and 71. The block casting number will be on the passenger side of the block toward the rear and will probably start with a D1 or a D0.
The Dove-C heads are decent heads because of the smaller chambers and easier to get the compression up on the big turds Ford came out with in 1972 forward. If you are looking at selling any of it, I may be interested in the block depending on the casting numbers. If you REALLY want to know more about 429 engines, go to google and type in 385 series engine forum. This forum has anything and everything you ever wanted to know about 429s.
broke33 is offline   Reply With Quote
Old 09-22-2005, 10:34 PM   #6 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
325 brake HP at the flywheel on 100+ octane gas. That was measured the old way too. So figure 280HP or so, assuming its built to stock specs. Exhaust ports are weak link for high performance. Detonation problems are common at 11:1 10:1, and sometimes 9:1 as well. Carefully polish (grind) down the sharp edges of the combustion chamber. Dont go crazy, just BARELY make it so it isnt sharp. If the heads are not assembled/rebuilt yet,yank out the valves and keep track of where they go. Open up the valve pocket area to just under the size of the valve seat. Do not mess up and grind on valve seat. Some say to also grind off hump in exhaust port, others say leave it. There are tons more things to do, but I wont bother ya with em yet. No info on the pistons, are they flat tops, or are they dished? Hopefully they are dished, cuz high compression needs 91-92 octane to be happy, and with gas prices going nowhere but up, trust me you need to run the cheap gas. If you are extremely lucky, you might stubme onto a 4 bolt main block (highly unlikely) If you do, they are worth a grip of cash.
masterbeavis is offline   Reply With Quote
