Member # 45629
Axle suggestions
i have a 78 F250. 2WD. im buildin it up to be pretty serious on the trails, but id still like to be able to drive it on the highway. i was wonderin what yall think i should get in the way of axles. i was thinkin bout just grabbin axles from a 4WD, cuz that seems easier than gettin rockwells or somethin. also, does anyone know if my rear axle is the same as the rear axles off the 4wd's? thanks.
Member # 54152
the tire size will determin what axel u will need if u are gunna run anathin bigger than a 35 or 36 u will want a dana spicer 60 front and a dana 60 or even better a dana70 in the rear ..more than likely u will have a d60 rear now and thats ok but a stock 9 inch halfton rear is stronger but it will work id reccomend a d70 rear and d60 front but ull pay from 800 to 1200 at a junk yard for the d60 front though now if u want a 35 or smaller u can get an 8 lug dana 44 front for a couple hundread but it wont hold up for anathing more than a 36 or so
2008 F250 CC SB Lariat 4x4. 700HP on fuel. 93 F150. 01 F350. 97 Ram 1500. |
Member # 42509
All right, let's cover a couple things. If you move your rear axle up front you will have to modify brackets and you're going to need to put steering knuckles on it.
For your transfer case you need something heavy duty so I'd go with an NP205. It is cast iron and bolts right up to a c-6. It only has a 1.96:1 gear reduction but later if you get really serious you can add a doubler box. Oh, and move this to newbie.
Semper Fidelis |
Member # 45629
sorry for all the newbie questions, but i got a couple bad ones here:
what does the number designate? (44,60,70) when you say 9-inch rearend, what does 9 inches correspond to? -Kit |
the higher the number pretty much the stronger the axle. d44 is 1/2 and 3/4 ton. dana60 is 1 ton and so is 70 i think. the 9" refers to the diameter of the ring gear in the axle its self
Bent Fabrications EVO4 Build, Magnacharged LQ4, Rocks, 47" LTBs |
#13 (permalink) |
Member # 42509
Here's the specs on axleshafts (as acurately as I can) from weakest to strongest.
D44 - 1.25" or close to it (less than 1.31") diameter axleshafts D60 - 1.31" diameter axleshafts (30 spline outers, 35 if you're lucky) D70 - 1.5" axleshafts (35 spline outers) 14b - 1.5" axleshafts For the front you want a Dana 60 because of the wide locker and gear selection and of course... strength. Rear you want to go large because its your main drive wheels, the 10.5" ring gear on the 14bb and 1.5" axleshafts are as beefy as they come. Not to mention you can pick one up for under $200 easy.
Semper Fidelis |
#16 (permalink) |
The junkyard closes to me has a Sterling FF that they want 500 freakin dollars from. Insane!
You really have to know what you want to do before doing this. How big are you going to go. If you see this being a cut up trail-only rig later, do it once and do it right by using a D60 from the start. If this is a DD or almost DD and you don't see yourself going more then 35-36" on the tires, then you can use a D44 front to save money, and as long as you don't go stupid with the skinny pedal you will be fine. That's the thing. You can break anything if you pound it enough. Fordtrucks, how can a 9" be stronger then a D60 in stock form? If his D60 were Semi-float it'd be close, but the D60 would still have the strength advantages. Extra pinion bearing....or larger shafts and ring gear. D60 SF vs 9" SF is close, but D60 FF there really isn't much comparison.
94 Ford F150 Almost got all my parts bought for D44/9" swap Front/Rear. 4.56, 35's, Lockright. Closing in on carnage time. Last edited by Saurian; 10-18-2005 at 07:33 AM. |
#17 (permalink) | |
I got my 96 10.25 FF for $160, $40 to ship |
#18 (permalink) |
Yeah, they're just proud of their sh1t. I've considered goin in with 200 dollars and seeing if cash will let me back my truck up and take it home with me. I don't like Sterlings though....
94 Ford F150 Almost got all my parts bought for D44/9" swap Front/Rear. 4.56, 35's, Lockright. Closing in on carnage time. |
#19 (permalink) | |
Member # 39126
[URL="www.damageinc4x4club.com"]Damage Inc. 4x4 Club - Milwaukee WI[/URL] [URL="www.wohva.com"]Wisconsin Off-Highway Vehicle Association[/URL] |
#20 (permalink) | |
Member # 25927
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here Dana 60 front 3/4 ton kits $350--> click here |
#21 (permalink) |
so much tech in this thread my brain hurts!
www.PolyPerformance.com WE GOT WHAT YOU NEED When people in the Taliban are riding around in better trucks than you, you might have a problem. |
