Member # 47479
Sterling 10.25 info
I just got a sterling 10.25 with a limited slip 4.10 ratio. I have no clue what year it is because it was sitting on the ground by itself at the bone yard. It has a wheel speed sensor, and the drums come off with out taking the hubs off. So how do I tell what year it is?
Fawkin Fordhead
Having a VSS means it's 87 or newer. That's all I can tell ya. All Sterlings have ourboard drums.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Believe it was either 90-up or 92-up didn't have the leaky tendency.
Who cares, run it! The VSS is the same. It'll work for ABS, or for speedo. You'll have to recalibrate properly (different teeth then an 8.8).
94 Ford F150 Almost got all my parts bought for D44/9" swap Front/Rear. 4.56, 35's, Lockright. Closing in on carnage time. |
Member # 47479
Thanks for the insight. I've got a spedo recalibrater already installed in my Bronco, so I don't think it will be too hard to fix the spedo. I use a GPS to set my speed by. Thanks again!
[FONT="Comic Sans MS"]Every day is a good day when you wake up, it's the rest of your day that goes to crap![/FONT] |
