#102 (permalink) |
Moderhater
Member # 16980
yea, i might try to snag a MSD box just to make the plugs burn cleaner..
anyone got one cheap? remember, this looks to be an unnessasary expense, since the original coil works..lol
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
#103 (permalink) | |
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet |
#104 (permalink) |
Moderhater
Member # 16980
Yea, i hate that crap ignition control module that always dies. my moms jeep has that. my older ford had that and it sucked. if i can find something cheap i will, but remember the purpose of this build is to get it solid, dependable, no bling, and no unnessasary expenses.
i could go with a 6a MSD box and just run it off the ignitor of the dizzy....it would elminate a lot of wiring that way... tires should be here on friday, but i have to lift it a little and hack the fenders before they will fit... i need to work on the electrical now untill my other parts come in
#105 (permalink) | |
Member # 13205
Granted I've been through two of them, but at $22.00/module, it's a lot cheaper than the MSD, even when I carry a spare. Spend the money on a good set of plug wires Texas can have hotter temps, and in my experience, that's what kills the stock modules. Fun project you have there. Keep postin' pics when your not busy spinnin' the wrenches.
True friends will laugh when you hurt yourself. Last edited by 79broncn; 12-07-2005 at 11:21 AM. |
#106 (permalink) |
Member # 17313
you couldn't pay me to run anything but a dursparkII..
Hell my uncle still runs DSII on his 600+hp big block... it has no problems igniting 114 octane with 12.5:1 compression..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
#107 (permalink) |
Moderhater
Member # 16980
ive been thru 10+ in the jeep. its the same module. chrysler/ford/jeep rejection ignition in it.... we've moved the module to diffrent places, all sorts of crap, still dies....so we mounted two on top of each other now. first thing to do when it doesnt start is swap those plugs over..lol
my 77 ford killed 3 or 4 of those things too...wierd. gonna work on the electrical now, since my parts arnt here yet, i gotta do something to it... and i should be working on the cars at my job..lol
#108 (permalink) |
maybe im one of the lucky ones, but i never killed the ignition box, only the voltage regulater. now watch that die on me tonight at 2am before i goto work. lol
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
#109 (permalink) | |
I'm with Jrod........Stock Ford ignition systems kick ass. They are tgood for 10,000 RPM's all day long. Can you say that about a stock HEI ? NO. I've run the stock duraspark II with healthy bigblocks and no issues what so ever. ![]()
#110 (permalink) |
Moderhater
Member # 16980
bought two 1157 bulb pig tails for the rear tail lights....im going to have to rewire the ENTIRE rear end, due to the stripped corroded crap thats back there. im going to start from the cab and go back. ill look up the schematics tomarrow.
1157 bulb holders x2 14.00 licence plate light x1 3.00 2012 remaining going to order some 4 1/2 wild horse coils for the front end. im assuming ill have to install them and check my caster before buying the c wedges for the front axle. going to build a drop arm for the front panhard bar this weekend. the stock one is super worn out. im assuming ill have to drop it approx 4 1/2 inches to make it where it should. that leaves me to the drag link going to the tie rod....im going to have to make them angled the same or im gonna get bump steer. i found a nice crack on the front frame rail where the leading bolt is on the steering box when i was replacing the hoses. ill have to remove the box and plate that area to repair it. that will be done at the house. suggestions on using a drop pitman arm? neassasary? not if i flip the tierod? ive seen the kits where you either drill em out and weld em in, or ream em out and stick an insert in them...... i think the drill and weld is where its at for durability. need a 9 inch crush sleeve. crap. i got some 2 inch wrangler springs at the house, you think those will work for the rear end, since my springs are broken?
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf Last edited by Halogrinder; 12-07-2005 at 09:21 PM. |
#112 (permalink) | |
Member # 3113
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies 79 Bronc XLT, 400/C6/404 Mogs/42 roks |
#113 (permalink) | |
#114 (permalink) |
Moderhater
Member # 16980
got the rear wiring straightened out (i think)
but i have a bad turn signal switch. lookin around for one of those right now. saterday hopefully ill have all the items to reassemble the rear axle again, and do the disc brake conversion.
#116 (permalink) |
Moderhater
Member # 16980
ordered front and rear extended brake lines from keithflux on the board.
i wanted braided steel lines going to the axles, and they needed to be longer, so i went this route. this may be the only "bling" found on the truck 90 bucks 1922 remaining
#118 (permalink) |
Moderhater
Member # 16980
well unfortunatly i wasnt able to touch the truck this weekend....the gears didnt get to me in time to work on it, so ill be doing it this week after work i suppose. i got my tires in, ill wait till i get it home, lift it, then throw the tires under it.
although i did go wheelin all saterday in a buddys rig. it was very refreshing to do it
#119 (permalink) |
Moderhater
Member # 16980
bought some cheap lights for it. got em at northern tool....gonna use them for rock lights, and im gonna try to mount two of em on the knuckle, so when you turn, the lights turn w/ the tires...we'll see.
lights 35.00 1887 remaining.
#120 (permalink) |
Moderhater
Member # 16980
UPDATE
ok got the windshield wipers fixed. there is a little ground that goes from the bracket to the body of the wiper motor. its worn out. i bent it up and the wipers work awesome. i have taken off the front plastic bezel off around the instrument cluster. IT IS COMPLETLEY UNMOLESTED. im having a hard time wanting to cut it up for a cheap stereo. does anyone need a super clean dash plastic? also i have the original AM radio out of the dash. UNMOLESTED. it would be a great peice for a restoration project if anyone is interested in it. got the driver and passenger door adjusted for the new-to-me BMW door seals i used ![]() still havent seen the gears in the mail.....braxton? Bought some more cheap ass lights for it 25.00 1862 remaining.
#122 (permalink) |
Moderhater
Member # 16980
bought some bc coils instead
4.5 winch coils 180 bucks shipped 1682 remaining.
#123 (permalink) |
Axes of E-ville
Member # 48097
Are you going to upgrade those brakes?
Despite what others may say, I swapped in a F250/F350 2wd master cylinder and booster and replaced the rear 1/2 ton wheel cylinders with 1 ton units in my 78 Bronco. My stopping abilities are outstanding. It also gave me a better pedal response. |
#124 (permalink) |
Moderhater
Member # 16980
have you read any thing on the thread?
rear end is getting disc brake conversion, as soon as i get my gears.... master replaced all brake lines were replaced braided steel lines used for drop down lines. perportioning valve for the rear. ![]()
#125 (permalink) | |
Axes of E-ville
Member # 48097
yeah, yeah, yeah.... I didn't read far enought into it.......In any event, this is a great thread with a lot of great 70's Ford truck ideas.....Thanks. |
