Member # 55567
Explorer leafs in a Ranger
I have a 91 Ranger with a sagging rear end, thought I had heard that explorer leaf springs could be used and would give about 2 inches of lift. Does anyone know if this is true? I've looked at 91 explorers and they have the axle over set-up instead of the axle under/block combination, but the mounts are in different locations. Thanks for the help.
~D |
Member # 17313
yes
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 57069
any year explorer/navaho leaf packs will work on the ranger. the best ones to use are the 4 door explorer leafs. all you have to do is flip the center pin on the springs and bolt them up. the 4 door springs should lift it up a good 2" maybe even 3" with nothing in the bed. I cant say anything about the 2 door explorer springs and the lift anount they give, but they will handle a load better than the ranger springs.
Member # 10063
Check www.therangerstation.com , there's quite a bit of info on Explorer spring swaps there.
Yes, basically you turn the centering pin over and bolt them in.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] Last edited by 4x4junkie; 11-29-2005 at 09:50 PM. |
