Ford 330? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2005, 03:45 PM   #1 (permalink)
AJ Johnson's Avatar
Member # 21274
Send a message via Yahoo to AJ Johnson
Ford 330?
I've got a 73 F600 truck with a 330 engine and 2bbl carb. What engine family is this motor? I'd like to put a 4bbl intake and carb on this.
[QUOTE=BellyDoc;8268286] It may not have been rape, but it was a vigorous copulation.[/QUOTE]
AJ Johnson is offline   Reply With Quote
Old 12-09-2005, 07:10 PM   #2 (permalink)
76HighBoy's Avatar
Member # 47479
It's an FE motor. But the medium duty FE motors have an extra exhaust port in the heads. That means you will need to run the factory exhaust manifolds with the motor (no aftermarket headers).
[FONT="Comic Sans MS"]Every day is a good day when you wake up, it's the rest of your day that goes to crap![/FONT]
76HighBoy is offline   Reply With Quote
Old 12-09-2005, 07:44 PM   #3 (permalink)
AJ Johnson's Avatar
Member # 21274
so, what's my best option for an intake?
Old 12-09-2005, 08:02 PM   #4 (permalink)
76HighBoy's Avatar
Member # 47479
On the 330 I had, I saw no differance on the intake side. I didn't try to bolt on an aftermarket intake, but the intake side on the heads didn't look any different. If you want to chance the $250 or so bucks it takes to get an Edelbrock performer intake, I think that would be your best (not nessesarally your cheapest) option. Cheapest would be to use a cheesy 2 to 4 bbl carb addaptor. Next least expensive option is to get a Holly 500 cfm 2bbl carb (they work great on the FE motors).
Old 12-09-2005, 09:14 PM   #5 (permalink)
JoeBlow's Avatar
Member # 35124
The exhaust cross over is in a different location on the FT engines (The heavy truck version of a FE). The FE has the exhaust crossover in the rear and the FT has it in the middle of the intake. So you cant swap factory intakes from one to the other. The Edel intake doesn't have a crossover so it might work but I don't know of any body who has done it. If you swap the heads and intake off of a FE engine you will see more power than just a intake swap. The bore on a 330 is small and I am more familur with the bigger 361 and 390 so I am not sure what heads will work as far as valve sizes go.
Go here for all the FT/FE info you need:
http://www.ford-trucks.com/forums/forumdisplay.php?f=51
HTH
82' 1-ton Bronco on 38" TSL's. 390FE swap soon...
JoeBlow is offline   Reply With Quote
