Member # 848
Rollin Marbles
Slapped a couple new fenders on and started in on molesting an EB grill on to my Bronco II. Check out those body lines !
Have to thank FearMe for this wonderful mod. From the moment I saw his, I knew what needed to be done. No more plastic shit to get broke from people rolling 36" SX's into my truck(EBSTEVE!). I get round headlights too!!! This mod also frees up valuable engine compartment space because the headlights mount in the grill, versus the innerbody. The inner body can then be removed. I'll have to build a new rad support though. FearMe's Bronco
SNOWTREK.org |
Member # 8941
Kreepy, i was just e-mailing fearme about that mod. He told me that he had to cut out 2 3/4" of steel from the middle of the grill to make it fit right. FYI sorta thing..
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1 |
Member # 6708
It gives the BII's that Dear-in-the-headlights look you should be able to fit a fat radiator in there now. Eric
'There will be pork in the tree tops by morning!'-Lion in Winter. 'Dear,dear.....what ever shall we do with mother.'-Lion in Winter. "Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson 'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!' |
Member # 848
yeah, FearMe only lives a few miles from me. He did cut a few inches out of the middle of his. I'm not going to do that though. He also welded his grill to the fenders. With just a couple bolts, he can remove the front clip. I'm not going to weld mine to the fenders. I'm going to attempt to make it bolt on.
Now I need to dig up the rings that go around the headlights. EB shit is expensive!!
SNOWTREK.org |
#5 (permalink) | |
Member # 848
Once I rebuild the rad support I'll be able to stand the radiator up straight and hook up the on-board air!!!
SNOWTREK.org |
Member # 8941
Note the slats in the grill. While your at it, check out that string of pictures. http://www.snort4x4.com/trips/hammersmarch There are alot of Roger's rig there. Flexy and what not ![]() ![]() By the way, who makes thoes keen beadlocks?
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1 Last edited by SMC; 03-25-2002 at 09:15 PM. |
