Swapped Out - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2006, 05:58 PM   #1 (permalink)
big460bronco's Avatar
Member # 59692
Swapped Out
Can anybody tell me why ford mixes there parts.
Went to parts store to by a master cyl. for 78 bronco and master cyl. wouldn't match up. Finally matched one up that was listed for 77 E-Van 250.
The prob. was that the ports were on the wrong side for the brake lines.
Any input would be nice.
fun in the MUD when I can,
40" ground hawgs, 9" lift, 460 & HD axles (8 lugs)
'78 bronco ranger and other stuff
[URL="http://www.xt4x4.com/main/index.php"]http://www.xt4x4.com/main/index.php[/URL]
[URL="http://www.supermotors.org/users/big460bronco67"]http://www.supermotors.org/users/big460bronco67[/URL]
big460bronco is offline   Reply With Quote
Old 01-23-2006, 11:02 PM   #2 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
because they can. OR a previous owner did the swapping themselves (most likely answer) Be glad it wasnt an AMC product. They bought their parts from other car manufacturers. It was anyones guess what would be under the hood
masterbeavis is offline   Reply With Quote
Old 01-26-2006, 08:05 AM   #3 (permalink)
Member # 59692
thanks for your input, but I was trying to figure out if someone else did it becuase a stock boosters stroke was also 2 1/2" shorter than the one that was on it also and that seemed like alot of work for a home mech. to do
Old 01-26-2006, 09:44 AM   #4 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
If you haven't bought and installed a "correct" m/c and booster for your Bronco, you may wish to use a 1-ton m/c and booster setup. All you have to do is reroute the brake lines an install a larger flare nut and re-flare a brake line.
Aces'n'8s is offline   Reply With Quote
Old 01-26-2006, 10:04 AM   #5 (permalink)
Member # 52361
I keep telling myself that it's because they are dynamic and constantly improving their product, not waiting for a new model year, or even a shift change. But that still doesn't explain why I had to buy 66 F350 2wd drums for my 75 F250 4wd. Luckily I worked for a parts store and I could get half a days wages trying to figure out what parts Mother Ford gave me .
PROJECTJUNKIE is offline   Reply With Quote
Old 01-27-2006, 09:08 AM   #6 (permalink)
Member # 59692
I found out that master cyl., booster and whole pedal assemble is out of 77 3/4 van.
