Member # 35034
f-150 diesel
i am trying to tube out a late seventies or mayb early eighties F-150 and then install a 7.3 liter diesel into it, what type of tranny do i need and where can i find a cheap pipe bender
95 Bronco on bags Last edited by kstatecruiser1; 01-30-2006 at 07:05 PM. |
Member # 43894
do you want auto or manual?
Id get a ZF 5 spd, unless you want auto... then Id try to hook up a C6 to it.
1993 F350 7.3 IDI, ZF S5-42, 205, Rocks, 145" wb. Wanna buy it? |
Member # 18283
If you want OD then ZF or E4OD are your choices. the auto won't be any harder since you will already have the computer for the engine and they are integrated.
If you don't need OD then C6 or t19 are your easy options without throwing adapters and such into the mix.
There are no rules. You have to think! |
Member # 43894
i would stay away from the E4OD. My dad has 160000 on the clock and hes on his third E4OD. Diesels tend to do that to auto trannies... esp when you haul or drive them rough...
#6 (permalink) | |
Member # 36102
why not use a f250 or an f350. there are more differences in the f150 and f250 than just the spring weights. the frames are made much thicker and are more capable of supporting the weight. The truck from this era all look the same and hell if you wanted you could slap some f150 badges on it.
Bubb Rubb
There was a nice F-350 4wd 4-speed 6.9L for sale here a couple years ago. short wheelbase, 4 door and had a sidewinder kit. If the guy didnt want an insane amount of money($5000) I would be driving it now.
IMO, if your gonna spend the time, get a cummins. They weigh a few hundred pounds more but I dont think you will notice the difference if your gonna run a 6.9/7.3. If your mind is set on a f-150 you better box the frame up front at least or its gonna bust.
this space for rent. |
