300 inline dimensions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-03-2006, 05:21 PM   #1 (permalink)
Member # 13707
How big is the 300 compared to a 302? Will the 300 fit in a bronco II? What bolt pattern is the bellhousing (will an AOD bolt to it)?
Correct me if I am wrong, but:
the 300 will have a better torque curve(espcecially with an auto) for crawling.
It should get better milage than a 302 for normal driving.
Toyoda is offline   Reply With Quote
Old 02-03-2006, 06:08 PM   #2 (permalink)
Member # 54152
The 302 will have better gas milage and more horse power and the 300/6 will have more tourke and less gas milage and also weighs more.I would use the 300/6 for crawling due to longevity and tourke.And if you have an aod with a small block bell pattern than it will bolt to a 300/6.It should fit in a B2.
2008 F250 CC SB Lariat 4x4. 700HP on fuel.
93 F150. 01 F350. 97 Ram 1500.
Fordtrucks is offline   Reply With Quote
Old 02-03-2006, 06:30 PM   #3 (permalink)
Member # 13707
I would have thought that with more low end torque it would get the better gas milage.
Old 02-03-2006, 07:44 PM   #4 (permalink)
Member # 50971
i definatly would not consider the 300 to be good on gas but aside from that it is impressive everywhere else.
fordnut is offline   Reply With Quote
Old 02-03-2006, 07:47 PM   #5 (permalink)
Member # 34702
the 300 is going to be a bit of a challenge in a b2, check out this explorer 302 conversion:http://www.explorerforum.com/forums/...37#post1113937
EMG7895 is online now   Reply With Quote
Old 02-03-2006, 08:25 PM   #6 (permalink)
Member # 41557
Heres a quote from Wanderer(he did it in a ranger):
I used an EFI so the firewall was cut to fit and a doghouse built like Vans use..but a carb'd 6 with the radiator moved 2in forward would fit without too much trouble...it was sweet!!..torque MONSTER!!! and easy to work on..tons of room to the sides..
I used the stock ranger mounts..ground the guide pin off the pass side..drilled out the stock I6 mounts and dropped it in...little hammering on the oil pan and firewall top then it fit like a glove..another buddy of mine did it with a carb'd 6 but discovered when he started moving the firewall back with a hammer that rust had eaten the body off his truck..so he scrapped the body and found a deal on another truck with a good motor...
I did the 4.9 M5od 1356 and everything but the t-case shifter lined up to the ranger body..I had to chop into the floor to make an access hole for the t-case..but no big deal there...
Ron Douglas of:
[URL="http://www.OverlandJourney.com"]OverlandJourney.com[/URL]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=623057"]Official Cummins Suburban Expedition Build.[/URL]
Cummins/6speed/HP 60
Colorado Ron is offline   Reply With Quote
Old 02-04-2006, 10:37 AM   #7 (permalink)
Member # 66772
My dad has a 302 and I have a 300-6 I get way better gas milage than he dose. I've also have a manual though. If you were to get the manual 4 speed with granny low then I would consider it but with a manual I don't know.
73' Ford F-150 short box, 92' Dodge Dakota
Mudadiction85 is offline   Reply With Quote
Old 02-04-2006, 11:28 AM   #8 (permalink)
Member # 29210
Send a message via AIM to Davethorik
My dad's 96 F150 4x4with the M5OD gets 23 hwy mpg @ 65, but he does drive like a senior citizen.
:laughing:
Davethorik is offline   Reply With Quote
Old 02-04-2006, 01:51 PM   #9 (permalink)
Member # 17313
efi 6's are a goofy motor... some make decent power, some are gutless..
Some get ok mileage, some get shitty mileage.. and there seems to be no connection between the power and mileage.
I've had two in my F-250, the first had "ok" power, the second is a dog, both had similar mileage, around 15-16 or so.
However, I've seen ALOT more that get around the 10mpg mark than the 20 mark.. Where as a old 1bbl motor makes a solid upper teens in WORST case scenerio in my expirances.. The old 1bbl ones always seemed to have more power too..
As for the size, I think your alot better off just doing a 302, or even better, a 351W. The 302 fits in a BII just soooo nice, and the power/weight balance on them is reallly nice. I still miss mine..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 02-04-2006, 04:31 PM   #10 (permalink)
Member # 13707
Well, I am back to thinking I will get a fullsize bronco. From what I have read and researched the 351w will be the better choice.
Do you think an injected 351w stroked to 393(AOD) will get 15 mpg on the freeway?
Old 02-05-2006, 12:06 AM   #11 (permalink)
Member # 17313
its all in the tune.. and whats around the motor... and whats in it..
Old 02-06-2006, 07:45 AM   #12 (permalink)
Member # 41653
yep...thats correct...they will fit..its not a "direct swap" but it will fit...and ALOT easier to work on it than the 302 that USED to be in that truck..
Gotta Love people who have "soon to have/be" in their signatures....Im soon to be thin,rich and nice..
yea right..
"They are little angels but they are trying to fuck the wings off each other!"
--Sturgell
Black eyes last but a week, the shame of sodomy lasts a lifetime.-TheRedHorseman
wanderer-RRORC is offline   Reply With Quote
