Member # 68431
manual tranny options?
Ok so i wanted to hear what people have to say about a good tranny for me to mate up to the HO 5.0 that i have. It is going into my ranger with a sas locked front and rear on 37's. I really wanna keep the stick but from the research i have done it isnt sounding like that is a very good idea.
My original plan was to get a t5 and just throw that in, but sombody on here told me that it was a bad plan. He also told me to look into a tremec 3550 because it is a much better tranny. The tremec seems to be a hard tranny to find though. I was hoping to keep a quick shifting 5spd because i have a NP 435 in my eb and it is a bad ass tranny for crawling but it sucks to shift, both in the time it takes to shift and the size of the gear gap. So let me know what you folks think about a good tranny. |
Member # 63546
I told you to get a tremec. Get a tremec or a ZF. DAMMIT. No T5s and no Mazdas. Look on mustang boards for tremecs. There are gajillions. You'll need a divorced x case of course.
mooktank.com -->Cummins B3.3 Explorer Blog |
Member # 11061
ZF is probably the best bet.
Using Advance Adapters you can use an NV3550, or NV4500. I have a Ranger that is getting a new dtrain 5.0/NV3550/d44/9" Divorced T-case is an option, but than you will have a pathetic first gear ratio.
I am a Bronco Nut! Current toy 74 Bronco |
Member # 24862
A Tremec 3550 would be nice for slick shifting and close ratios but a ZF would be the stronger of the two options.
One of the problems I see with the 3550 isn't so much availability, but cost. Last time I looked (it's been awhile) 3550s were fairly spendy, new or used. The ZF has a decent gear split and it shifts far better than any granny 4 speed. You'll never get it to shift like a 3550 but, IMO, the ZF would hold up better. You'd blow 3rd gear out of a T5 in no time.
77' F-150 SWB on one tons 06' F-250 Harley Davidson CC SB, tuned and stuff |
Member # 63546
you could always go with a TKO500 or 600. Theyre rated at 500 and 600 ftlbs of torque respectively. ZF is like 450 I think. I would go ZF but it will never shift like a car tranny.
#12 (permalink) |
Member # 11061
You want to look for an F250 with a 351. I think they are in some 351 powered 150s too. My local bone yard has several, they are all in early eightys 250's.
If you dont mind the price of advance adapters (fat chance) you can use New Venture 3550 (not tremec 3550) out of a late model jeep. It has good gearing, it is syncroed so it shifts well, and it can hold some decent power. Also You can shoehorn a Dodge NV4500 in there (again with aa adapters). By the way what tcase are you going to use?
#14 (permalink) | |
Member # 68431
By the way if i do find a F250 with a 351 am i going to need an adapter to the 5.0 i know 302's and 351's are similar but i dont know if it is a direct swap. Last edited by 2dub; 03-09-2006 at 10:17 AM. |
#15 (permalink) |
You will not need an adapter to go from the 351 to the 302. They have the same bolt pattern. I swapped in a ZF from a 302 behind my 351. I love the granny gear 5.7X-1 and od is real nice too. I plan on putting another ZF in my exploder with a 302. Plus there is not that huge of a demand for the ZF, I got mine for about $450.
Will
Besides there is no such thing as just boobies, they are all magical orbs of happiness! Mmmmmmmmmmmmmm Boobies. |
#16 (permalink) |
Member # 11061
http://www.advanceadapters.com/catalog/t18.html
You can use either of those. Keep in mind that the ZF is huge.(for a ranger) the reason I am not running one is because even with a 3" body lift it is a shoehorn operation and the shifter wants to be in the same spot as the firewall. The NV3500 (not tremec) is almost the same dimensions as the mazda m5r1 in my ranger. If you do go with the zf you can use the bw 1356 tcase from the same truck. What year Ranger is this going in? I am working on a similar project. I have a 2000. I found a 2000 Merc mount. 5.0 that I am using. I aslo picked up a donor 78 bronco for the axles. I would love to see pics of your rig.
#17 (permalink) | |
Member # 68431
My ranger is an 89 it has a eb dana 44 and a full floating disk break 9". right now it is sitting because i blew up the front axel. Both u-joints blew, messed up the yokes, and the short side shaft is broken in the houseing. When i start my new job in the next couple of weeks i will go chromo shafts and ctm's. I have only had it going for a short while but when the 5.0 goes in i will probably change a lot of the suspension (learning from my mistakes). any way here are some pics ![]() ![]() ![]() some of these are posted in the pictures of your rigs thred and i would mix it up but i dont have a digital camera sorry. |
#18 (permalink) | |
Ford Bigot
Member # 31227
Run the ZF. The Tremec 3550 and TKO will not fit in a Ranger as there is no one adapting them to transfercases. The ZF shifts far faster than the old T18s and NP435's so it's not too big of a deal. You will find the S5-42 in '88-93 F250s with 351W or 300 I-6s, the S5-47 came '94-97 F250s.
Project Flat F***er (Fender) Project SR5.0 |
#19 (permalink) | |
Member # 68431
#20 (permalink) |
Member # 4243
Difference is the torque rating. I thought the S5-47 was strictly a diesel application though
Another idea is a Ford T19 close-ratio. 4 nice driving gears instead of 3. Nice & short too. Compensate for crawl ratio with better t-case gearing.
90-93 CTD jalopies |
#21 (permalink) | |
Member # 24862
#22 (permalink) | |
Member # 1919
#25 (permalink) | |
Member # 68431
