what does your 460 get mpg??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2006, 06:48 PM   #1 (permalink)
THE HANS's Avatar
Member # 13313
Send a message via AIM to THE HANS
i just got a 88 f 350, standard cab, long bed. it has a 460, and a 5 speed
just wondering what gas milage you guys get..????
I LIKE TO PARTY
ECV 7-11
THE HANS is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 06:51 PM   #2 (permalink)
Member # 48716
Send a message via AIM to VerticalTRX
14.3 mpg on the highway, 10-12 in town, anywhere from 7-12mpg while towing depending on load.
Edit: Specs on mine, 6640lbs empty. 3.55 gears, 33" tires, rest is in the sig. BTW, those numbers were checked via GPS, so I know they are right. One particular time while driving roughly 60mph for about 500mi I saw slightly over 15mpg
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet
VerticalTRX is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 08:33 PM   #3 (permalink)
LeviGarrett76's Avatar
Member # 13654
5900lb fullsize on 44 tsls, no od 5.13 gears. got 8 mpg @70 mph w/ holley,just over 10 with q-jet
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency.
LeviGarrett76 is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 12:42 AM   #4 (permalink)
Member # 41529
6300lb 78f250 325/85/16 xml tires (38's and a bit, but really heavy) 3.55 gears no od, cam, headers, stealth intake, 800 edeljunk, some exhaust porting, i get 11 on the highway at 70-75mph, 5-9 in town, depends how much i play the pipes.
JR650 is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 05:47 AM   #5 (permalink)
Member # 41653
92 CREW 4x4 longbed..no cats..true duals....EFI 10-12 empty..8 loaded..doesnt matter how heavy..
great truck...
Gotta Love people who have "soon to have/be" in their signatures....Im soon to be thin,rich and nice..
yea right..
"They are little angels but they are trying to fuck the wings off each other!"
--Sturgell
Black eyes last but a week, the shame of sodomy lasts a lifetime.-TheRedHorseman
wanderer-RRORC is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 06:31 AM   #6 (permalink)
BUZZISCRAZY2's Avatar
Member # 17399
Send a message via AIM to BUZZISCRAZY2 Send a message via Yahoo to BUZZISCRAZY2
A half hour to 45 minutes - 22 gal
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT]
[FONT="Arial Black"]Current vehicles[/FONT]
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
95 F350 (Blown Crazy")
95 F350 ("Crazy Too")
87 Ranger (2wd)
00 Excursion
04 Navigator
BUZZISCRAZY2 is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 09:45 AM   #7 (permalink)
Member # 70034
Henry Ford Didnt bless the 460
Yeah right dont run a 460 if your looking for fuel economy. they just dont get it. The engine im running now i only get about 5 or 6 just depends on how many hondas pull up to the stop light while im in town. On the other hand i used to have a 71 Ford Mercury with a 429 CJ and a holly 750. I got 22 MPG and could blow the doors off any hot rod camaro in town. Just an idea.
Stump385scj is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 11:54 AM   #8 (permalink)
THE HANS's Avatar
Member # 13313
i wasnt expecting good gas milage
i was just wondering...
I LIKE TO PARTY
ECV 7-11
Old 04-03-2006, 07:39 PM   #9 (permalink)
Member # 70034
Originally Posted by PineyPower
I used to drive a 1995 F-450 Rollback tow truck with a 19' aluminum Jerr Dan body on the back it was 4X2 460EFI with ZF 5speed. not exactly sure what gears wher in it, probably 3.55's cuz that seems to be common gearing, for some reason I thought 4.10's tho, like I said not exactly sure, but loaded or empty that thing would go 99mph (falls flat on it's face computer shuts off fuel at 100mph) and I used to drive it like nascar everywhere I went, and it averaged 11mpg, average steady cruising speed I used to run about 75-80, so it must have had 3.55's cuz you really didn't even need 5th gear, and I really didn't use it unless I was going over 60-65, but you could still burry the speedo in 4th gear, and you didn't really need 1st gear unless you wher loaded on an incline, and couldn't use it very far, pretty much about one second after you take your foot off the clutch you had to shift into second gear. most of the time on flat ground you could start it in second gear.
I think that is very nice considering I drive an 88 F-350 4X4 SRW with a 5.8EFI and a C-6 4.10's and 315/75R16 (35x12.5) average cruising speed about 60-65, rarely go over 75mph ever for any reason... no load in it just using it as an every day driver it gets about 6.5mpg if I drive it, my old lady can somehow make it get 7.8 just driving back and forth to work, and one time she actually made it get 8.2 I really don't know how... if you spend a day offroading and crawling around in low range it gets about 4-5mpg, same thing if you try to pull weight, I used to have a 1973 Holiday Rambler 28' camper, I don't know the weight of the camper, but it had 2 axles, and was made of mostly wood, so I know it was heavy... heavy enough to rip a class 3 out of the truck when I floored it over a whooptie-doo cuz I started to get stuck in the soft sand...
I have been told that the reason the 460 got better milage is because it didn't have to strain all the time to get out of it's own way, and the 351w does
the 351 also has Bassani performance Y-pipe 3 inch straight pipe with no cat, and a mild pulling cam in it, the F-450 was stock and had way more power than my 351 ever dreamed, or ever could in it's wildest wet dream, and the 460 got almost twice the milage. the F-450 was a work truck and I didn't have to pay for the fuel, so I really didn't care, but I bet if I drove it like I drive my F-350 it would probably get like 14-15mpg
so in conclusion if you want economy don't run a V-8 period or a drive a truck or anything with 4wheel drive for that matter how ever if you do plan on pulling anything and want something semi economical get a diesel, or if you really want a gasoline V-8 definately go with a 460 don't skimp out and get a small block thinking you are saving, come to think of it, screw small blocks all together if your truck weighs over 3000lbs even if you don't plan on pulling anything, nobody says you need to use every last horse under your hood just because you have them, and just because something gets shitty gas milage does not mean it is strong, or fast, and just because something gets over 10mpg doesn't mean it's for pussies
What does that have to do with my post
Old 04-04-2006, 07:57 PM   #10 (permalink)
Member # 2725
85 F250hd, ex cab long bed 4x4, 4.10's, 33's, no OD, small crane cam, edelbrock intake, headers, true duals with no cats, some exh porting, and 600 AFB, gets about 9 around town, 11-12 highway around 65 and 7-9 towing. My dad had a 95 F250hd/auto, all stock and got 13 highway and about 9 around town. It doesn't pull as nice as a PSD, but it's right in my price range!
187racing is offline   Reply With Quote Quick reply to this message
Old 04-04-2006, 08:46 PM   #11 (permalink)
Member # 43526
Send a message via AIM to 71BRONCO71
i wish i got 12 mpg... i have a 302!! and i only get about 9 mpg.... sucks
Libertarian- Root word: LIBERTY
KEEP PUBLIC LANDS OPEN TO THE PUBLIC
71BRONCO71 is offline   Reply With Quote Quick reply to this message
Old 04-04-2006, 09:02 PM   #12 (permalink)
Member # 18282
97 F250 4x4 HD 4.10 on 33's I get about 9-10 town and 11-13 hiway...oh has auto trans too.
I'm what you call your basic famous.
Stix is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 12:32 AM   #13 (permalink)
Member # 15648
hans you know fred.. 8mpg no matter what :P
88 Toyota 60/14b 350/th350/duals on links and Fodees
IronClad is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 10:04 AM   #14 (permalink)
Member # 52979
95 F350, 8-9 in town and about 11-13 highway (E40D)
zakt is offline   Reply With Quote Quick reply to this message
Old 04-05-2006, 05:11 PM   #15 (permalink)
Member # 70034
I agree with you completly on the first part big block in a big truck will be better than a small block in that same big truck.
me bitching about people who thing they have something awsome because it gets 7mpg, my F-350 gets 7mpg and it isn't very strong or fast,
I agree and disagree with you here it just depends which people think they have bad azz shlt. I have a 514 thats blown and juiced in my truck (and yes its taken 10 years and lots of money to build) ive gotten it up to 10mpg but had the timing way retarded and it ran like shlt. running like i like it i get max 5mpg but i can run 13.50's in the 1/4 mile in a 8,500lb truck. im not tryin to disagree with you im just saying sometimes power comes with a price at the pump. but so does junk. so your right both ways.
Old 04-05-2006, 05:34 PM   #16 (permalink)
Member # 28703
Low - Low = 4 MPG.........
So what?
1 Ton on 3/4 Ton with lots of stuff on it.....
[SIZE=3][COLOR=Red]Jackass Wheelers[/COLOR][/SIZE]
Custom BodyWork By Humbug...
87 Ford is offline   Reply With Quote Quick reply to this message
Old 04-06-2006, 06:58 AM   #17 (permalink)
Member # 38172
Send a message via AIM to Shadow Crawlers Send a message via MSN to Shadow Crawlers
We have an 87 f-350 and it gets about 8mpgs no matter how loaded it is. Pulling a heavy ass overhead camper and a trailer with a buggy I am suprised how well it pulls it's weight. The way I look at it is we only use it to go wheeling and the amount we spend on gas is way cheaper than a new truck payment. Sure a new truck with an oilburner would be sweet I would rather spend my money on our buggies.
The only thing that I need to fix now is the steering column is screwed up and can't shift into 1st or 2nd gear. Anyone know how to fix this? we were thinking of just putting a floor shifter in it and call it good. Good steering columns seem to be pretty hard to find around here.
It still has the factory holley which we rebuilt, any reccommendations on a good carb for it? I am also considering putting an RV cam in it. It has a 150k and is still tight as a french whore Hasn't been started in about a year and it fired right up
L8rz
Chris
Shadow Crawlers is offline   Reply With Quote Quick reply to this message
Old 04-06-2006, 10:09 AM   #18 (permalink)
no v8? why drive?'s Avatar
Member # 64333
Send a message via MSN to no v8? why drive?
'97 EFI 460, standard cab 2wd NV4500 3.73s detroit 31's: 8 - 11mpg mostly on the 8 side...
no v8? why drive? is offline   Reply With Quote Quick reply to this message
Old 04-06-2006, 09:41 PM   #19 (permalink)
Member # 13110
shitty...
... according to an old educated "Jeeper" I am just another "Toyota Faggot" ...
Poohbair is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 07:57 AM   #20 (permalink)
Member # 70034
I know quarter mile times dont impress off roaders but i use it as a put down to street racers and imports. i have been driving my truck every day for about 5 years. not only will it out drag a honda itll allso pull its ass off. I get called at least 20 times on the weekends "come pull me out" Its an all around truck cus thats the way i built it. Itll haul ass, climb rocks, throw mud for miles, and pull every one else out of that big ass hole no one knew was there
Old 04-07-2006, 09:49 AM   #21 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
hrmmm a 460 getting 12 mpg, that makes me wanna get rid of my 400, the 400 only gets 4 mpg on a good day
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 03:36 PM   #22 (permalink)
Member # 54152
I have no idea on my milage but its really good for some reason.I have a 466/435/208/3.50=diffs.In my 81f150 with 35s and i get a lot better milage than my buddys 351W in his 85 bronco.Eddie carb and intek to.
2008 F250 CC SB Lariat 4x4. 700HP on fuel.
93 F150. 01 F350. 97 Ram 1500.
Fordtrucks is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 06:22 PM   #23 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
4 mpg
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
Old 04-07-2006, 06:47 PM   #24 (permalink)
Member # 69692
88.5 F-250 HD 4x4 5 speed years ago got 13-15 highway, about 10 around town unloaded. 3.55 gears. Was always looking for another gear. A 6 speed would have been great with a taller OD. Sold her with just under 200k on it. It was getting a bit tired at that point.
kblackav8or is offline   Reply With Quote Quick reply to this message
Old 04-10-2006, 11:30 PM   #25 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
'77 F250 4x4 with a mild 10:1+ motor, 1 7/8" headers into 3" primaries out 3" mandrel bent pipes, 4.10 gears, NP435, 285/75/16's 10MPG. Same truck with 36x14x16.5 swampers, about 8MPG.
I personally think that ANY properly tuned V8 in a light duty pickup (F150-350) should get a minimum of 8 mpg, unloaded, while expecting 10MPG to be the norm with normal street tires, without racing the thing.
masterbeavis is offline   Reply With Quote Quick reply to this message
