I just can't....figger it out! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-10-2006, 08:06 PM   #1 (permalink)
Hyde's Avatar
Member # 53554
So, the explorer still runs like crap. Im going to pull the cats this weekend if I can find some time. I was going to pull the fuel filter last weekend but couldn't figure out how to detach the lines from the filter. I cant figure out why I have no power
I break stuff.
Gearing is a crutch for lack of horsepower.
Hyde is offline   Reply With Quote
Old 04-10-2006, 11:59 PM   #2 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
Could this be anymore cryptic? What year, and engine? Well at least you listed a make and model. If it is a 97 or later Exploder with an OHC 4.0 it sounds like it has slipped a tooth on the timing chain to one of the cams. Is it easy to fix? No. It's cheaper to buy a running take-out engine.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
Project Flat F***er (Fender)
Project SR5.0
FordFascist is offline   Reply With Quote
Old 04-11-2006, 04:39 AM   #3 (permalink)
Member # 16383
You need special tools to remove the fuel lines. They look like little plastic donuts. You can get em at any auto parts store for uner $10. They clip on over the fuel line then you slide that up into the spring connector and they pop right off.
Good leaders are scarce, so I am following myself.
rabidranger is offline   Reply With Quote
Old 04-11-2006, 08:41 AM   #4 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
i didnt need a special tool, $3 at the dollar store for a 16oz hammer and they will come right off
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
Old 04-11-2006, 11:43 AM   #5 (permalink)
Member # 20167
My special $10.00 took never freaking worked. My fuel line chewed up my cheap plastic tool and made it useless for any future applications. I should have gotten the $3.00 hammer first. LOL!!!
i'm new here - STFU
F0rdFre@k is offline   Reply With Quote
Old 04-11-2006, 03:21 PM   #6 (permalink)
Hyde's Avatar
Member # 53554
Alright, its a 91 eddie bauer with the 4.0, duh. p.o.s auto. I have an old school 302 with a c4 i could put in it although ive ben holding out for a fuelie 5.0 or a 4bt(wishing)
I break stuff.
Old 04-11-2006, 03:26 PM   #7 (permalink)
85f150dsel's Avatar
Member # 43079
don't buy the cheapie tool, buy a set from MAC or snap on that are about the size of a stubby wrench instead of the POS ones you are buying. and don't buy the ones form autozone, as i broke that POS using it once. even the 20 dollar one from sears is better than the autozone one
BTW have you checked for codes, just becuase the light isn't on doesn't mean one didn't throw......
No power as in rich running or lean......change the o2's lately? how about the plugs/wires. why not start with a tune up or more info
85f150dsel is offline   Reply With Quote
Old 04-11-2006, 03:29 PM   #8 (permalink)
Hyde's Avatar
Member # 53554
new plugs, wires, air filter, ran some injector cleaner
I break stuff.
Old 04-11-2006, 09:51 PM   #9 (permalink)
Member # 10063
I just use a small flat-blade screwdriver to pop the fuel filter clips off...
The new filter will come with new clips too, should you break the prongs off.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 04-11-2006, 10:52 PM   #10 (permalink)
Member # 49586
after 1979... brain... can't.. think.... can't comprehend.. must.. leave thread!
bah! computers!
Slow is offline   Reply With Quote
Old 04-11-2006, 11:17 PM   #11 (permalink)
Hyde's Avatar
Member # 53554
I know what you mean, shit lol
I break stuff.
Old 04-12-2006, 08:54 AM   #12 (permalink)
85f150dsel's Avatar
Member # 43079
those are different, these are round and have a spring inside of the around the perimeter of the line, you have to use a tool or you might bust the spring. plus this is made into the hard line it is a replaceable type deal like those palstic ones.
I am assuming you have SD EFI, tried cleanign the throttle body and the IAC sensor, it sits on the throttle body. Are all the vaccum lines connected
Old 04-12-2006, 02:45 PM   #13 (permalink)
Hyde's Avatar
Member # 53554
I cleaned the MAF, whats the IAC? I'll have to try cleaning the throttle body. Im pretty sure all the vaccum lines are connected, anyone know how many there should be?
I break stuff.
Old 04-12-2006, 03:24 PM   #14 (permalink)
Member # 37870
They're reffering to the disconnects on the fuel lines located up by the drivers side of the firewall.....
94 Ranger with alot of crap
chris1044 is offline   Reply With Quote
Old 04-13-2006, 10:12 PM   #15 (permalink)
Member # 10063
He said fuel filter in his opening post.
Yeah the other ones are different.
