9 inch gears - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2006, 11:11 AM   #1 (permalink)
tsmall07's Avatar
Member # 26580
Send a message via AIM to tsmall07
9 inch gears
can i put 5.13's on my stock carrier or is there a break like on the 44?
thansk for the help
2000 F350 Dually (For Sale)
[url]http://pirate4x4.com/forum/showthread.php?t=1001572[/url]
tsmall07 is offline   Reply With Quote
Old 05-02-2006, 02:00 PM   #2 (permalink)
Member # 27392
No!
Swat.
Blown is offline   Reply With Quote
Old 05-02-2006, 02:02 PM   #3 (permalink)
tsmall07's Avatar
Member # 26580
that wasn't really a yes or no question
Old 05-02-2006, 02:06 PM   #4 (permalink)
Member # 5021
There is no carrier break for the 9"
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 05-02-2006, 02:13 PM   #5 (permalink)
Rubicrawler's Avatar
Member # 2037
Yep, the Rockslut's right, no carrier break in the 9"
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Rubicrawler is online now   Reply With Quote
Old 05-02-2006, 02:17 PM   #6 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
You will have to grind the pinion bearing support though.
Once you set it up its easy to tell where it hits.
Mark
welndmn is offline   Reply With Quote
Old 05-02-2006, 06:32 PM   #7 (permalink)
tsmall07's Avatar
Member # 26580
i got a nodular third...will i still have to grind on that?
Old 05-02-2006, 06:40 PM   #8 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
flip a coin, you may or may not. it is really not that hard to grind a little material away
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote
Old 05-02-2006, 06:57 PM   #9 (permalink)
Member # 48716
Send a message via AIM to VerticalTRX
Hey man, get that thing done and come wheelin'! I finally got my '79 up here and it'd be good to see some more Fords out on the trails.
As for the gears, they shouldn't be any trouble. Grind a little if needed, but I don't think you'll have to, if so it'll be miniscule. I just re-geared my 9" (along with a 100% rebuild and spool), and it was a super simple task.
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet
VerticalTRX is offline   Reply With Quote
Old 05-02-2006, 08:57 PM   #10 (permalink)
bronco69drp's Avatar
Member # 36795
i am running 5.83 gears in a stock case. no grinding, with either the stock carrier & now a full spool.
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s
bronco69drp is offline   Reply With Quote
Old 05-02-2006, 10:17 PM   #11 (permalink)
tsmall07's Avatar
Member # 26580
i'm workin on it!!
once i start working some this summer i should be able to get the loan i need to buy everything and start doin.
my plan is 5.13's and 38's
welded rear and some kind of full carrier locker in the front (depends on how much i have left after getting gears) and running on propane. i have everything except for the gears and front locker and tires
Old 05-02-2006, 10:21 PM   #12 (permalink)
jopes's Avatar
Member # 8469
either buy a full spool or a used detroit from ebay. welding a nine is a PITA.
Old 05-03-2006, 05:22 AM   #13 (permalink)
Member # 48716
Yeah, since the 9" has a closed carrier you have to take the spiders out, weld them on the table, (hope the pin lines back up), and re-install...more than likely it wont line up and you'll have to ream the spiders to get the pin to go through.
If you want to stay cheap, get a $30 mini spool and a chromoly cross pin. Much stronger than welded, yet fairly inexpensive as well.
For the front, you are planning on running 38's on a D44, locked? If so you should budget in some 4340 chromo shafts and CTM u-joints right off the bat, otherwise you'll be pulling you hair out changing broken shafts all the time. 34-35" tires are about the biggest I'd feel safe running with a locker and stock shafts, but even then 760X joints are a must.
You coming to the club end of year party tonight?
Old 05-03-2006, 08:14 AM   #14 (permalink)
tsmall07's Avatar
Member # 26580
i guess a mini spool would be the best way to go. i'm in the process of getting a chromo cross pin
i'm also leaning more and more toward chromo shafts from what i hear from people. i think i'm going to try it out with stockers first and see how it goes. if i'm light on the pedal i should be ok.....but i'm never light on the pedal
i just found out the party was tonight when you just told me. haha. i'll come by for a bit but i don't know if i'm going to stay.
Old 05-03-2006, 08:59 AM   #15 (permalink)
Member # 48716
Sounds good, just put some 760X u-joints in your stock shafts with full-circle clips and they should last a while with a light foot.
BTW, not sure if you got the messages on listserve, but the party is not at the same camp site as last year. Its the other way from pandapas pond, up towards the shooting range.
