73-79 F-series Hydraulic Cutch ideas?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-28-2006, 06:53 PM   #1 (permalink)
Member # 5326
Anyone have any good ideas or junkyard tech on how to convert from the relay rod to a hydraulic clutch system?
Old 05-28-2006, 07:08 PM   #2 (permalink)
Member # 14848
wilwood master cylinder and CNC slave, about $165 for the whole deal, and I have used both types and they worked well.
Master Cylinder
Push type slave
Pull Type Slave
Pedal
Another option would be a Post 1980 SWB slave and any of the ford hydraulic bells, or find a vehichle with an external slave like 4th gen camaro and adapt that.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 05-28-2006, 07:29 PM   #3 (permalink)
Member # 16408
I used the Dodge clutch m/c on my conversion. I welded a piece of plate on the side of the pedal assembly. I cut a more or less square hole for the clutch slave. The rod was attached to a bracket welded onto the clutch pedal.
It appears to me that that the Ford and Dodge clutch m/c's and slaves are mix and matchable to fit your application. I have pictures of what I did on both fordtrucks and turbodieselregister.com
'78 Ford F250 4x4 SC D70/60, 6bta Cummins (not quite stock!), Southbend CON-O, BHAF, NV4500, NP205.
Force to fit. File to hide. Paint to cover.
Scot is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 06:39 AM   #4 (permalink)
Member # 14652
Send a message via Yahoo to billp
I used a Wilwood master cylinder and some kind of a Chevy slave cylinder. I don't remember the exact application of the slave, sorry. Made a bracket for the slave and bolted the master to the firewall, which was kind of spongy there so I welded a strap to it next to the MC.
billp is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 08:49 AM   #5 (permalink)
Member # 17313
On my buddies, he just built a bracket similar to the 80's hydro clutch setup, and bolted it to the bellhousing bolts. This way it uses all stock 86' ford parts.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 09:36 AM   #6 (permalink)
Member # 5326
I needed pics....thanks.
Since I am dealing with an FE I doubt there are any factory bellhousings that are set up for hyrdo. I am just going to have to make a bracket. Most anything is better than the factory setup in my truck these days.
