bell housing bolt pattern - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2006, 05:36 AM   #1 (permalink)
Member # 39105
I am wondering if anyone knows if the 4.6 liter engine might happen to have the same bell housing bolt pattern as the 5.0. Basicly I can get a 4.6 liter engine extremly cheap and was thinking of it for my 73 EB. Wondering if it will bolt to my 435. Any info on this subject would be super.
thnxs Mikey
1973 FORD BRONCO,435,D20,DANA 44 W/ARB,9" W/ARB, 35" TIRES
broncomikey is offline   Reply With Quote
Old 06-18-2006, 06:26 AM   #2 (permalink)
Member # 47246
Send a message via AIM to NHRedneck
thnxs Mikey
totally diff engines/patterns. the 4.6l is a wide angle block, and the 302 pattern is for a narrow angle block.......
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 : [url]http://www.cardomain.com/ride/2145548[/url]
Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 : [url]http://www.cardomain.com/ride/393604[/url]
NHRedneck is offline   Reply With Quote
Old 06-18-2006, 08:16 AM   #3 (permalink)
Member # 19666
Send a message via Yahoo to ImNotRight
Nope.. YET ANOTHER bellhousing pattern! Fawkin Ford, eh?
QUOTE=TheHawes;15027873
If it wasn't for pussy, I'd hunt them fucking things.
ImNotRight is offline   Reply With Quote
Old 06-18-2006, 09:19 AM   #4 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Apparently the modular pattern is similar to the SBF one, and can be made to work with a SBF bell.
I have no idea if that's true tho.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
Old 06-18-2006, 09:29 AM   #5 (permalink)
Member # 17313
I "believe" the first year of the 4.6's in lincolns used the normal SBF pattern
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 06-18-2006, 10:03 AM   #6 (permalink)
Member # 39105
Well it seems so far the audience is diveded in half, I guess I still dont know.
what to do???
Old 06-18-2006, 10:09 AM   #7 (permalink)
Member # 13110
best way is to take a SBF bellhousing, and take it w/ you to look at the 4.6 and see if it fits...then you know for sure
... according to an old educated "Jeeper" I am just another "Toyota Faggot" ...
Poohbair is offline   Reply With Quote
Old 06-18-2006, 10:52 AM   #8 (permalink)
bremen242's Avatar
Member # 28687
i am 95% sure this is the case
bremen242 is offline   Reply With Quote
Old 06-18-2006, 12:58 PM   #9 (permalink)
Member # 52361
I would be really surprised if this were true. I think the t birds got these motors first, maybe 91? They were plauged with problems IIRC, and it would be unlikely to find a decent 15yo motor, and an overhaul would be $. Maybe use an auto tranny from an early 4.6 4wd and mate it to an earlier tcase?
PROJECTJUNKIE is offline   Reply With Quote
Old 06-18-2006, 03:13 PM   #10 (permalink)
Member # 17283
Send a message via AIM to mtnbronco
I'm working on the same swap idea. Issues I have found so far.
The 4.6/5.4 is wide and high. Will have to remove inner fender skirts. Most of the items on the firewall need to be modified. ie steering, brake, and exhaust outlet will need to be modified. If I was to do this right I would build a tube chassis in the front and position the engine forward.
70 Bronco 351w efi, C4 and many extras "'hates the pavement""
mtnbronco is offline   Reply With Quote
