Water proofing... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2006, 11:12 PM   #1 (permalink)
Member # 70604
Send a message via AIM to YamanX Send a message via MSN to YamanX Send a message via Yahoo to YamanX
Water proofing...
How does one water proof a distributor?
How can I make a cheap snrokle for my 89 F-150.
It's not the size of the dog in the fight, it's the size of the fight in the dog that matters.
YamanX is offline   Reply With Quote
Old 06-21-2006, 06:02 AM   #2 (permalink)
Member # 26216
Send a message via Yahoo to Gummi Bear
Stay out of the river, and you won't need either one.
You live about an hour from the best wheeling in the southwest. Why the hell do you want to mess with the mud?
Go to Clayton.
I consider myself a student of the game, it's just too bad I'm in special ed...
Gummi Bear is offline   Reply With Quote
Old 06-21-2006, 06:07 AM   #3 (permalink)
Member # 16383
I have never had any luck, since they should not be made air-tight because they heat up and need to have a vent. But I have had good luck with a product I cannot remeber the name of. I think it is called wire dry or something. Comes in a blue and white aeresol can at Murray's. When the dizzy gets wet inside, a few shots of this and your good to go again. Not really preventative, but good for after. WD-40 will also work in a pinch, just don't use too much.
Good leaders are scarce, so I am following myself.
rabidranger is offline   Reply With Quote
Old 06-21-2006, 06:37 AM   #4 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
For the ultra cheap, a bead of silicone around the lip of the distributor (before you snap the clasps) works just fine. But, like it was said, it should have a vent to expell ozone (I think).
As for a snorkel, you could always try some 4" corrugated drainage pipe and a SS band. Or, mabe you could work some magic with some 4" PVC.
Aces'n'8s is offline   Reply With Quote
Old 06-21-2006, 07:29 AM   #5 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
just run a breather for the dist. then seal it all up and run the breather line from the dist. into the snorkel
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote
Old 06-21-2006, 12:22 PM   #6 (permalink)
Member # 70604
In answer to going to Clayton, I would love to go there, but I really can't travel with my truck yet, much rather just keep it local, till I can trailer it places. My father came up with the idea of having a bead of silicone around the lip on the cap, and then letting it dry, and then put it on.
Any suggestions on were to run the Snorkle through? Just the side of the truck to the top, or what?
Old 06-21-2006, 04:09 PM   #7 (permalink)
tsmall07's Avatar
Member # 26580
Send a message via AIM to tsmall07
obviously this picture doesn't show the cheap route, but it does show you where you should run it.
2000 F350 Dually (For Sale)
[url]http://pirate4x4.com/forum/showthread.php?t=1001572[/url]
tsmall07 is offline   Reply With Quote
Old 06-21-2006, 08:16 PM   #8 (permalink)
Member # 70604
Kinda what I figured. But I'm sure mine won't be as fancy.
What happens when it rains?? And you are driving.
Old 06-21-2006, 09:00 PM   #9 (permalink)
tsmall07's Avatar
Member # 26580
not enough water will get into the snorkle to make a difference (probably). i'm not sure if the 89 has the up draft air box, but that would make a huge difference. if you don't have the updraft air box and you're going to modify the intake this much, you may want to put one of those in anyway.
Old 06-21-2006, 09:14 PM   #10 (permalink)
Member # 70604
I just planned on probably just taking from the Throttle body to the outside and then to a K&N.
Old 06-21-2006, 09:31 PM   #11 (permalink)
tsmall07's Avatar
Member # 26580
imo, if you think you're going to get in water where you'll need a snorkle, you should look into getting a mid 90's f150. the air travels up through the filter so the water doesn't usually fallow. saved my ass numerous times
Old 06-21-2006, 10:03 PM   #12 (permalink)
Member # 70604
It travels up through this setup, but I have taken the filter out and it be soaking.
Old 06-22-2006, 05:41 AM   #13 (permalink)
Member # 16383
Tsmall, do you have any pics of the engine bay for how that snorkel mounts?
