Member # 17313
hypothetical 400 build.
So here's the deal, My buddy has a 400 in his bronco/truggy. last sat. it engulfed a bit of silt mud, through the rear main, possibly wiping the crank(its grooved pretty good)
What we have to work with
Now, a 351M and 400 have the same 10.297 deck height, and both use identical 6.580" rods, with .912 wrist pins, and 2.311" rod journals. 351M pistons have a compression height of 1.947 400 pistons have a compression height of 1.647 stock 351M pistons would then be .020" below the deck stock 400 pistons would then be .070" below the deck. dodge rods are 6.123" with a 2.125" journal, and a .984 pin The pistons could be milled out to the larger diameter of the dodge rod, thats no biggie. Now lets say we take our 351M long block, that is a MINT engine, that needs a crank. Now lets say our 400 crank is to far gone to be turned, and use normal bearings, say for comparative reasoning, we must take .050 off it to clean it up. picture offset grinding it, down to a 2.125" journal, allowing for the .050 needed to clean it up, thats giving us and ADDITIONAL .161" of throw. Now lets crunch some numbers. stock 400, 10.297" deck height, 4" stroke, 4" bore, 6.580" rod, 1.647" compression height, .070" below the deck. Our Kustom 400 stroker. 10.297" deck height, 4.030" bore, 4.322" stroke, 6.123" rod, 1.947" compression height, .066" below deck height. The result would be a 441" stroker, with 9.68:1 compression ratio, just about perfect for pump gas, and using basicly all free parts, and only paying for the crank to be offset ground, and the pistons to be machined to accept dodge rods. Off course zero decking it would bring the CR up to 11:1.. note we wouldn't be going with 11:1... thoughts?
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. Last edited by Jrod-13; 07-17-2006 at 09:11 PM. |
11:1 with the stock heads would kill you with so much detonation you wouldnt even know what to do..... i wouldnt go over 9.40:1 with the stock style modified heads..... go nuts with the cheapo build, just to get too excited and forget about the important aspects of the motor and its uses....
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 : [url]http://www.cardomain.com/ride/2145548[/url] Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 : [url]http://www.cardomain.com/ride/393604[/url] |
Member # 51243
dude, unless you are planning on running race fuel in it, I wouldn't even run it that high on compression. 9.0:1 would be the highest I would go.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
Moderhater
Member # 16980
do it and fawk the naysayers
![]() keep the CR down though. send me yer heads for a bad ass valve job and it be mo betta
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
Member # 17313
I guess I should have said, there would be NO intension on going that high of compression, I just through that out for shits and giggles. This would obivously be a pump gas motor, going with the 9.68:1 CR I stated
Jopes, I looked at the 434 kit a while back, its a nice kit, but if this project ever materlized, it would need to be way under that kinda money... I'm talking spending money on machine work, and bearings, thats about it.. halo, thanks for the offer, but the heads being used are allready rebuild( couple thousand miles ago), but of course will get a little porting before hand. I realize 400's have a real issue with detonation, which zero decking helps... problem being, there is no way to do it without the compression ratio getting oout of hand, aside form new pistons, which kinda defeats the purpose of it.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 40259
Sounds like a fuin project motor in the works. Couple questions/comments about yr numbers and assumptions that I didn't quite understand:
1. What pistons exactly were you including in the equation?..flat-tops..12CC dish..? 2. Zero-decking has no effect on anything but compression unless there is a quench pad present on the heads (i.e. closed-chambers). It's the squish distance between piston top flat and quench pad that helps control detonation. Thus..to gain a quench pad, you would need to get your hands on a set of 302C aussie heads..which is what Jopes and I are running. 3. You can zero-deck the setup and use the Aussie heads and still have a CR in the range you are looking for..you simply dish the piston tops where the head quench pad 'is not'. IIRC correctly, it takes a 32cc dish to achieve around what you are looking for with a zero-decked setup and Aussie heads. Don't take that number as absolutely correct...my memory ain't that good and I'll have to go look at my build notes again.
69 Bronco trail rig 72 Bronco TT racer 78 Bronco trail rig |
#10 (permalink) | |
Member # 40259
1. Bush the rods, cut the pistons for clips and use shjorter wrist pins (or grind sonme shorter) 2. Bore and hone the wrist pin bores in the pistons and keep the press-in pins.
#12 (permalink) |
Member # 40259
The problem with the 'high RPM/high HP' approach is that..this engine is for a trail rig, yes?. The 400, or better yet, a stroked 400, gets you the grunt you need at an engine RPM you want it to be at. We design/build our 400s for peak torque in the 2500-2900 RPM range....so the HP numbers are nothing special, but HP is not what yr after here.
#13 (permalink) | |
Member # 50730
#14 (permalink) |
Oh boy Possum and Orrin back at it again. I can't wait to see how this turns out when I get back to Tech this fall.
Good luck with he build.
KC0TRP Webmaster MTU 4 Wheelers 05-07 [url]www.mtu4x4.org[/url] "Life is not a journey to the grave with the intention of arriving safely in a well preserved body, but rather to skid in broadside, throughly used up, totally worn out, shouting HOLY SHIT WHAT A RIDE!!!" |
#15 (permalink) |
Member # 50730
I run a chevy 383 stroker in my hot rod that makes right at 500hp and 550ftlb. of torque.But I've been thinking about putting that motor in my dads scout terra,and building me a destroked 400 for the hot rod.Cause it sounds better running 9-10,000 rpms flying past some punk ass kid in his rice rocket with his jaw droped.
LOL.
#16 (permalink) | |
Member # 40259
..don't I know that!. For a couple years, i was 'sans trail rig' and took my EB MX racer to several trail events, including Tellico..twice. Nearly 500 HP in that thing..at 7300 RPM. IIRC it didn't even break 200 ft-lbs at 2000 RPM..a six-banger 170 would have more torque at that RPM. Quite the show that was..hee hee....instead of using 'tread lightly' on obstacles, I would say 'assault obstacle with extreme prejudice' more accurately describes the driving technique..(I do NOT want to have to do that again either... ).Sorry for hijack...
#17 (permalink) | |
Member # 40259
#19 (permalink) |
Member # 17313
good info guys!
BMC69, you nailed it on the rpm range thing, for the wheeling we do, low rpm grunt rules. I USED to have a torquey 351W in my truck(power band peaked at about 4500), now I have a high strung 302 in it, that spins to 6800. I'd give anything to have the W back, but it was a matter of needing a motor, and I had the 302 sitting around. After riding in above mentioned bronco, I was inlove with the grunt of a 400, it's almost like my 7.3 The pistons I used in the comparision were the stock 12cc dish 351M pistons. as for the bushed vs. boring, I think(for us) boring them would just be simpler(and cheaper) to do. Getting 2v assuies would be the cats ass, but isn't in the budget. 32CC chambers sounds right for the aussies, IIRC, thats the guy who builds the 434 kit sells, and I believe the stock 400 truck pistons are a 32CC also, I might have to whip out the burret, plexy glass, and ATF to messure them.
#20 (permalink) |
Member # 48567
Out of curiousity, what are the Aussie heads worth there? I could send them to you guys, no probs.
I have about 10 sets in my Garage, from Standard 302 cleveland ones upto some pretty wild ones. |
#21 (permalink) |
Moderhater
Member # 16980
UH like 50 bucks a set, ill buy all 10 from you
#22 (permalink) | |
Member # 40259
..actually I think that they are being given away, just to get them out of Oz. Seems you lot made a whole mess of 'em out of recycled steel from some nuke plant demolition. Seriously, the ARD1AE closed-chamber stockers go for $275-300 per pair, complete, as-pulled.
#23 (permalink) |
Moderhater
Member # 16980
I know, i was trying to be sarcastic
#24 (permalink) | |
Member # 40259
#25 (permalink) |
Moderhater
Member # 16980
