Member # 52337
Need help to identify this traction aide
I picked up a 77 non banjo style ford 9 inch. i need to know what kind of traction aide this is. I dont see any clutches like in most limited slips. is it a Posi, Trac-lock or Locker?
Here are the pics ![]() this next pic shows some of the numbers on it they read CRAW 420 ![]() the last pic shows the other side with more numbers on it they read 70E25 MCC 70
#3 (permalink) | |
Axes of E-ville
Member # 48097
It's not a spool....if it were, it would be one solid piece. I believe that's Ford's version of their open differential. ![]()
Member # 52337
the tag that was caked on the centersection reads 3L50 from my understanding the L stands for locker of some sort. also i bought it from a friend that was parting out the 77 f150 did a burn out in the truck and left 2 25 ft long black marks.
#5 (permalink) | |
Member # 50730
#7 (permalink) | |
Axes of E-ville
Member # 48097
Member # 17313
take a picture from the backside of the ring gear, thats the easiest way to tell a trackloc from a open carrier
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 57166
How many spider gears are in it? 4 or 2, could be a track lock. I just got rid of one, look inside the middle, is there something that looks like a little cube? If so, its a 4pinion track lock
87 pathfinder HPD44 wristed radius arm, yukons, super joints, detroit True hi9 spooled 4 link 5.38's WH variable rate coils on all 4. |
#13 (permalink) |
Member # 57166
Oh by the way, Through my research.. make sure its not a 9 3/8" housing.. got screwed on one of those before.. The 4pinion track locks were found in alot of those.. NO GEARS! But the Carrier is good for 9" gears.
Post some more pics of the entire housing and the backside of the carrier as stated by quick and dirty
#14 (permalink) | |||
Member # 17313
#15 (permalink) |
Member # 56456
5/8 head on the ring gear bolts on a LS rather than 3/4 for open diff.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205 Last edited by Fordman500; 07-25-2006 at 10:17 PM. |
#16 (permalink) | |
Member # 57166
Dude, step away from the bong.
