5.8 performance parts? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2006, 09:29 PM   #1 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
Having trouble finding much aftermarket for the 5.8 in terms of performance upgrades. Anyone know of a source? Or even online discussions for hopping up 5.8's? I must be searching with incorrect terms.
Clodhopper is online now   Reply With Quote Quick reply to this message
Old 07-26-2006, 09:33 PM   #2 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
there is plenty of aftermarket for all 3 flavors of the 351's
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote Quick reply to this message
Old 07-26-2006, 11:55 PM   #3 (permalink)
more god and guns
fullsize80cherokee's Avatar
Member # 20331
jegs, summit, ON track performance in Englewood....
fullsize80cherokee is offline   Reply With Quote Quick reply to this message
Old 07-27-2006, 07:42 AM   #4 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
Mechanical upgrades to the lower end. That is great, but doing so increases fuel and air needs. How about mods to the fuel system?
Old 07-27-2006, 07:58 AM   #5 (permalink)
Ditchrunner's Avatar
Member # 34517
Did you mean the 5.4 Triton engine instead? There is a plethora of parts for the 5.8l 351w engine. Intakes, cams, ignition, headers, blocks, heads, cranks, rods...
Ditchrunner is offline   Reply With Quote Quick reply to this message
Old 07-27-2006, 07:58 AM   #6 (permalink)
derrick36's Avatar
Member # 47671
You can find all the 5.8 info you could ever want over at nloc.net.
The lightning, and standard truck 5.8s are built a bit different, but you can do any of the mods those guys are doing.
There is a TON of info over there.
derrick36 is offline   Reply With Quote Quick reply to this message
Old 07-27-2006, 07:59 AM   #7 (permalink)
Member # 14629
1 liter ~ 61 ci. 5.8L = 351W. For EFI, you can install bigger injectors, bigger fuel rails, aftermarket pressure regulator, and higher flow fuel pump. Just be sure to pick the right combination of parts that work together.
gddyap is offline   Reply With Quote Quick reply to this message
Old 07-27-2006, 08:10 AM   #8 (permalink)
derrick36's Avatar
Member # 47671
See how far the stock stuff will take you though. There are lots of people making plenty of power, with stock stuff.
Go over to nloc for the proof.
Dont just assume bigger is better.
Old 07-27-2006, 05:01 PM   #9 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
nope, never have. I have this thing torn a fair ways down and was thinking about what was possible, and not terribly unreasonable, to do to pop it up. Guess I am just exploring possibilities to weigh against the wallet.
Not being very fluent in the language of engines and fearing I know just enough to get in trouble, I thought I would ask a question. This is a 5.8 from a 90 F250 destined to be mounted in a 72 EB. I figured painting the beast would add about 5 or 6 horses minimum, ya know the visual zoomy effect.
I will go try nloc.net and see what I can find.
Old 07-30-2006, 06:57 AM   #10 (permalink)
wheelin66bronco's Avatar
Member # 44308
Personally I would ditch all the 92 EFI stuff, buy a mustang harness and all the SEFI stuff, and a 351W upper and lower intake.
My engine is a 69 block, world heads, comp roller conversion kit and Motorsports upper/lower and all mustang SEFI stuff with a cobra computer.
I absolutly love the setup, Indead it will cost a bit but I stocked up on all the parts and then put it all together.
I'm in fort collins if you wanted to stop by sometime, I have the whole front clip off right now tubing it out so it would be easy to check it out if you are interested.
ΜΟΛΩΝ ΛΑβΕ
98' 12v, qclb, lots of fun parts. No rice
96' Bronco Sport build
You know why black people never get bitten by sharks? They think it's whale shit.
wheelin66bronco is offline   Reply With Quote Quick reply to this message
Old 07-30-2006, 05:02 PM   #11 (permalink)
Member # 4178
Send a message via AIM to mlogan24 Send a message via Yahoo to mlogan24
Like has been said previously, the aftermarket for the 5.8 is HUGE. Your life will be much easier if you put on a Mustang style intake (GT-40, Edelbrock, Trick Flow) and, for the 72 Bronco, use a harness from http://www.fordfuelinjection.com. From there you can use anything from the Mustang 5.0 aftermarket. Quite frankly, it really sounds like you haven't done much research, as the Windsor series (especially the 5.0) is one of the most aftermarket supported powerplants out there.
LOAD "*",8,1
mlogan24 is offline   Reply With Quote Quick reply to this message
Old 07-30-2006, 06:44 PM   #12 (permalink)
Member # 49744
www.coasthigh.com, www.windsorfox.com, www.fordmotorsports.com, www.painlesswiring.com i used a 91 5.8l with a 95 mustang cobraR upper and lower and a painless harness in my 89 ranger. worked great. coast high and windsor fox are big helps with 5.0/5.8 build ups. i know you already have your lower end but if you can try to find a 94-97 block only years that came with roller cams
[FONT="Franklin Gothic Medium"][SIZE="2"][COLOR="SeaGreen"]after monday and tuesday even the calendar says WTF!!!!!!!!!
96 f350 powerstroke.[/COLOR][/SIZE][/FONT]
gfbgreaser289 is offline   Reply With Quote Quick reply to this message
Old 07-31-2006, 07:30 AM   #13 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
Yeah, well, when you know as little about engines as I do, you need a starting point, or you just sit spinning your wheels getting nowhere. After spending alot of time looking at parts for the 5.0 everywhere and not finding much for the 5.8, I came to the conclusion I was looking for the wrong thing and needed some help.
Sorry if I am wasting board space. Doubt I am the only one out there in the same situation.
