Member # 8243
Hydro assist pics
Rockhog and I are getting ready to do hydro assist on our rides and I am looking for any pics of the ram install on a EB. Looks a bit cramped with the trac bar. I do have the tie rod flipped. Thinking of using the West Texas kit.
Jay |
Member # 29
The bronco is Differnt from the other ones because of the trac bar and the tie rod flip does not make it any easier. Youa lso have the coil buckets in the way. My advice is to have Matt send yu the ram, Once you get that figured out, get the rest of the parts bolted on. I cna't hink of how to do it on the EB.
DImitri
1974 FJ40 in the works 2006 F250 crew cab longbed powerstroke for towing duties |
Member # 8243
CoryL- There are no threads on an EB hydro assist in any forum. I searched before I posted and always do.
Flatty- this is going to be quite a challenge, if I decide to do it. EB front ends are a mess with all the crap in the way.
Jay Last edited by jslater; 04-23-2002 at 09:24 PM. |
Member # 29
I have set up 3 of these already. If you decide to do this, let me know, I can give you a hand with it. I would go with the west texas setup. Call Matt and tell him Dimitri sent you. he will help you out any way you can imagine.
Dimitri
Member # 9872
Here's a few pic's, I'm using a full width hi-pin 44 so I have a little more room to play with, looked at the standard width looked a little more challenging.
The first two pic's are using electrical conduit to just find locations, the last one is where I'm at right now.
68 Bronco, 5.8 F.I., A.O.D., 3.8 Atlas II w/32 spline output, Detroits F/R, Full width 44/9" 31spline, 37"X17"BFG/KM's, 17"X8" Allied bead locks w/4.5 B.S., 4whl.disk. |
Member # 9872
Member # 9872
I used the West Texas off-road kit myself, and you are right, it's very cramped. It'll be impossible to mount the ram Matt sends you without relocating your track-bar to the top of your axle housing. You can see pics on how I set mine up at My web site .
If you have any other questions, feel free to PM or email me. |
Member # 6708
The June issue of Four Wheeler just came out and it does an artical on the Rock Ram install into an EB. Worth a look for a different way to install.
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter. 'Dear,dear.....what ever shall we do with mother.'-Lion in Winter. "Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson 'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!' |
#12 (permalink) | |
Member # 8613
Pete
06 Dodge 2500 CTD 05 Jeep Liberty CRD 95 YJ spring over, high steer and 35in KM2s |
#13 (permalink) |
Member # 8243
I read the 4 Wheeler article and that is the only way that I could see installing a ram. Rock ram does look smaller the the Industrial cylinder from West Texas, both should fit though. Man I just finished fab'n the trac bar setup to complete the extended radius arm install. Now I have to cut it off and start over.
Jay |
#14 (permalink) | |
DOOOHHH!!!! I hate when that happens.......Good luck man and be sure to take some pic so the other EB'rs have a idea how and what goes into this.. Man I want the Set up my HP 44 on my ford like they did on that EB....
Keep the rubber side down!!! Absolute power corrupts absolutely, Which is a problem if your absolutely powerless. |
