Member # 63061
what does a 94 F-250 weigh
I had to push my 94 ford back in my drive way, I almost couldnt do it. Its got the 460, 8 foot bed, super cab. Im trying to tear it down to get to exhaust manifold and it can't be started now.
#6 (permalink) | |
heh, i just use my quad or dodge spirit
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
says "yall" alot
Member # 13671
Push by rolling the tire. One shoulder on rig, other pushes tire. Try pushing a spooled rear rig that was parked with the wheels turned.
Hey kid, are you going my way? Hop in... we'll have ourselves a field day |
#8 (permalink) | |
no thanks, it was hard enough getting off the rollback and into the garage
#9 (permalink) | |
Member # 63061
#10 (permalink) | |
that changes alot, now you can take about 450# off just cuz its 4x2. without a front axle it is alot lighter but it will be a heavy bitch prolly no lighter then 5600#. find a buddy that has the same truck or next time your at the local pick-n-pull read the lable on the door if yours is that bad you cant see the weight
#11 (permalink) | |
Member # 18283
BTW your rear axle unless swapped is a sterling 10.25 not a dana 60 your truck should weigh in right around 6k
There are no rules. You have to think! |
#12 (permalink) |
Member # 51243
My truck in my sig below tips the scales at 5700 pounds. Its a short bed regular cab truck so I imagine that your is probably closer to 6000 with the long bed and extended cab.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#13 (permalink) |
Member # 13110
I just had my 87 F250 4x4 xtra cab, 460, 4spd at the scales... just me and my buddy (145lbs each) in the truck, no fuel in 1 tank, 1/4 tank in the other and NOTHING in the bed or in the cab.... weighed 6010lbs...
... according to an old educated "Jeeper" I am just another "Toyota Faggot" ... |
#14 (permalink) | |
Member # 63061
