1990 F350 build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-13-2006, 08:57 PM   #1 (permalink)
Member # 10385
1990 F350 build
Just bought a 1990 F350 XLT 4 door long box. 5 speed manual transmission w/4.10 gears. Power everything. Even has power captians chairs for the driver and front passenger, instead of the old bench seat. Gonna be my new tow rig. Body was in great condition (minor scratches and paint chips) and the interior is perfect. 114000 on the OD. The only downfall, the 7.3 is shot. Dropped a valve. The PO pulled it and it's sitting in the back of the pickup along with another compleate 7.3. Fortunatly it's under a topper. Now comes the fun part of rebuilding it.
Besides adding a turbo set up, what can I do to make the engine stronger. How else can I tune this thing to be a tow rig/camper special? Does anybody make a drop in crate motor, or should I rebuild? I don't think I want the chalenge of putting a power stroke in it.
I'll get some pics saturday when I go back to pull it home.
I prolly won't sleep tonight just thinking about it!
My girlfriend said if I spent one more dime on my Jeep she would leave. Man I'm going to miss her!
Tippy is offline   Reply With Quote
Old 09-13-2006, 09:14 PM   #2 (permalink)
Member # 47300
intercooler would help with power and lower EGT's. With 4.10's my guessing is that your engine is gonna be screaming down the highway, might consider bigger tires to balance it out.
83 chev pickup LPG350/400/208 on 10b/14bff on 37 iroks
tenpack is offline   Reply With Quote
Old 09-13-2006, 09:54 PM   #3 (permalink)
Member # 10385
Yea, I was planning on running 33's or 35's, depending on budget. Don't want to get too carried away since it will be my tow rig.
Old 09-13-2006, 10:57 PM   #4 (permalink)
Member # 70366
Lower the compression ratio if you want to make an IDI turbo motor last . 4.10's with 33's for towing , 35's or more daily driver
benttoy83 is offline   Reply With Quote
Old 09-14-2006, 03:14 AM   #5 (permalink)
BUZZISCRAZY2's Avatar
Member # 17399
Send a message via AIM to BUZZISCRAZY2 Send a message via Yahoo to BUZZISCRAZY2
460 is a direct swap...........
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT]
[FONT="Arial Black"]Current vehicles[/FONT]
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
95 F350 (Blown Crazy")
95 F350 ("Crazy Too")
87 Ranger (2wd)
00 Excursion
04 Navigator
BUZZISCRAZY2 is offline   Reply With Quote
Old 09-14-2006, 06:46 AM   #6 (permalink)
Member # 6733
Not exactly.
Unless you mean that it's a direct swap after he replaces the core support, the engine crossmember, engine mount stands, and the transmission.
But I'm guessing you don't mean it, because that would be a stupid fawking thing to say.
Team Fat Shit and the Traveling Circus
saf-t scissors is offline   Reply With Quote
Old 09-14-2006, 06:54 AM   #7 (permalink)
Member # 10385
What compression ratio do you sugest?
Old 09-14-2006, 07:07 AM   #8 (permalink)
Member # 4438
Yeah, I've always felt that an intercooler really helps the performance of a naturally aspirated engine. My old 351 got an extra 100 hp by just adding and intercooler and a K&N.
Yeah, another great suggestion. Have you ever tried to start and IDI motor with lower than 20 to 1 compression? It'll take plenty of ether or a combination of a grid heater AND glow plugs.
Now for real advice from an IDI owner and modifier:
If you rebuild it, use Malle pistons with the heat reflective coating on top, and a slightly shorter piston to account for compression gain upon head milling. If you don't mill the head, they will drop your compression from 21.6 to 1 to about 20.8 to 1.
I have had an IDI Ford motor of one sort or other for 10 years. They are quite bulletproof when maintained correctly (keep an eye on oil level, these motors use about a quart every 1200-1500 miles). My 86 has 210,000 K on it, 180,000 of that with a Hypermax turbo kit. I make 12 psi max, and it is plenty to tow my Jeep around. I run a 35 inch tire with a 4 spd (t-19) and can comfortably run 65 mph on the highway getting 18 mpg all day long (2750 RPM). The truck makes 225 HP and 440 ft lbs, about what a stock Powerstroke makes. Summary: IDI motors are an excellent, reliable motor, be happy with your purchase.
Those who dare, win. Wish I had a Tuesday filter.
afecko is offline   Reply With Quote
Old 09-14-2006, 07:26 AM   #9 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Sweet truck, I love that body style.
Because the motor is blown.....
http://www.fordcummins.com/
One of the guys I know did this, and he seems to love it.
Mark
welndmn is offline   Reply With Quote
Old 09-14-2006, 11:19 AM   #10 (permalink)
Member # 10385
What's a good intercooler to use? Aftermarket such as banks, or OEM replacement from later model?
What if I don't need new pistons? The truck came with two compleate 7.3's, so I have enough parts to make one. I was hopeing I could re-ring it and do the heads, assuming the block doesn't need too much machining. I was pricing out rebuilt kits, and the ring/rod/bearing kit is about $600, but you add pistons and it jumps to $2100.
Keep the ideas comming. I can't wait to get some pics and get it home!!
Old 09-14-2006, 12:03 PM   #11 (permalink)
Member # 17313
to make any decent power, you need the turbo.
if you don't, the biggest things are opening up the exhuast, and the pump mods.
I run a 88' F-350, identical to yours, but a reg cab.
All i have done is
cut out the soup bowl
turned the pump up about 1/2 a turn
bumped the timing up around 2 degrees
straight piped the exhuast.
With 285's on it, it pulls just fine, getting around 13mpg running at 75mph.
with 35's on it, it dropped it to about 10mpg pulling, and it ran out of power after around 70mph. I also found I was downshifting to 4rth alot on hills.
if you don't put a turbo on it, you don't want the big tires.
these motors are goverened at 3300rpm, and make peak Hp right there, and will also run it all day long. Your best pulling power is right around 2500rpm. coolant runs cooler, EGT's run cooler. motor pulls better, etc.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 09-14-2006, 02:14 PM   #12 (permalink)
Member # 4438
It's a joke, man, you can't use an intercooler on a naturally aspirated engine. Bolt on a turbo kit, and then you'll be ready for an intercooler.
The Hypermax turbo kit is very nice, doesn't pull as hard on the bottom end, as the turbo is a non-wastegated design, but it gets better mileage on the highway as NWG turbos have much less back pressure. If you don't want a turbo (trust me you really, really do) Stan's headers makes a sweet set of long tube headers that really help these engines breathe.
When you are rebuilding the 7.3, make sure you have the block checked for porosity in the cylinder walls. Coolant cavitation is notorious in 7.3's, and the bubbles eat through the cylinders after about 150k.
As I said, I have the Hypermax unit on mine, and the fuel pump turned up to maximum, and a straight 4" exhaust. I am very happy with it.
Old 09-14-2006, 06:06 PM   #13 (permalink)
Member # 10385
OK walked into that one! I'm going to put a turbo on it, that I know. I've been looking at the ATS and Banks, but neither one of their kits comes with an intercooler.
Please explain to this diesel noob the difference
Is there anything that can be done to the block at that point or are you SOL?
Old 09-17-2006, 11:14 AM   #14 (permalink)
Member # 10385
Here's a pic after I got it home. A few more pics will be posted in the tow rig forum.
Old 09-17-2006, 04:04 PM   #15 (permalink)
Member # 70366
19.5 to 1 , no problems starting it yet , although it hasn't gotten below 10 here in a while . Check out hypermax as far as rebuild componets , quality chit
Old 09-18-2006, 09:14 AM   #16 (permalink)
Member # 4438
Yes, you can have the block sleeved with new cylinder liners. Not cheap, but will yield a superior strength cylinder.
Old 09-18-2006, 05:47 PM   #17 (permalink)
wheelin66bronco's Avatar
Member # 44308
Don't mess with fordcummins (rippoff) but a 12V would be the way to go.
When my 7.3 goes in my 96 a 12V is going in.
No wheelin rig right now.
98 QCLB 4x4. Built 47RE, Bags, Guages, Pumped up, Exhaust, TW Guard Dog 35's, Ford knuckles/hubs.
Looking for 1996 Ford Bronco
05 Dodge free-spin conversion /forum/dodge/880388-my-diy-2005-dodge-dually-4x4-5-9l-free-spin-kit.html
Originally Posted by broncolou View Post
LS motors are like tampons....every VAG has one!
wheelin66bronco is offline   Reply With Quote
Old 09-22-2006, 06:14 PM   #18 (permalink)
Member # 10385
Do you have another supplier/parts list for this swap?
Old 09-24-2006, 07:40 AM   #19 (permalink)
Member # 44308
Check out www.cummins-conversion.com. There is a LOT of good info on there.
05 Dodge free-spin conversion http://www.pirate4x4.com/forum/showthread.php?t=880388
