Member # 51278
Two cat converter?
I have a 95 F150 4x4 with a 4.9 and it seems to have two cats back to back then a muffler, is this right? Or am I just losing my mind.
If im not losing my mind why are there two and should i leave it that way? Im getting ready to put a flowmaster on it and im going to get rid of anything that may be causing restiction. Thanks guys Jeremy |
Member # 14629
Two cat converters are not uncommon. My California spec'd Toy Tundra has three cats. 49-state Tundras have two. As a result my Tundra is spec'd with 5 less hp than 49-state Tundras.
#4 (permalink) | |
Member # 26164
1990 Bronco (Eaton ELocker rear) 1986 F350 Crew Cab 2001 Isuzu Rodeo 1986 Bronco 1981 Bronco 2007 Wrangler JK |
Member # 51278
Not sure if its a resinator (sp) or not. Sure looks like a cat to me. Im just ganna pull both and replace with one good high flow converter, I figure that should do the job.
We don't have Echeck here so i don't think it will raise any issues. |
#6 (permalink) | |
dont run a cat at all then, or just punch your current one out and save $100
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
i punched out the cat on my cousins 96 eclipse RS and no errors from the O2 and it sounds alot better like that. he was so amazed at the sound and better air flow, i swear he was ready to hump my leg
