radius arms? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2006, 03:13 PM   #1 (permalink)
brandon916's Avatar
Member # 28438
Send a message via AIM to brandon916 Send a message via Yahoo to brandon916
radius arms?
i need some pics/ideas for my radius arms! i am swapping in a 44 out of a 79 bronco in my explorer. i have the stock arms, also i have 10.5in. extensions and also i have a set of 1.25 by 1.25 in. hiem joints. dont know what route i wanna go so i need some imput thanks guys.
brandon916 is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 08:08 PM   #2 (permalink)
Member # 33830
The only problem with running the extentions is that you will hang up on whatever brackets you come up with so consider staying stock length and wrist the pass. side arm.
mad_boi is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 08:17 PM   #3 (permalink)
Member # 49744
heres what you do. use ranger rear shackel mounts and put them on the outside of your frame. bolt them on or weld them what ever you choose to do. thats what i did. member if you are running the fs setup the original setup is that much wider then the bronco/ranger setup. if you need anymore help let me know. ive done it a bunch of time. if you step up a lil bit more and get 3" wide jonnies they bolt right into the shackle mounts. use soft ride explorer lift spings and just cut the bottoms enough to mount them into your rad arms.
[FONT="Franklin Gothic Medium"][SIZE="2"][COLOR="SeaGreen"]after monday and tuesday even the calendar says WTF!!!!!!!!!
96 f350 powerstroke.[/COLOR][/SIZE][/FONT]
gfbgreaser289 is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 09:52 PM   #4 (permalink)
Member # 26910
Extended
'99 Explorer - Full Width 44/8.8 on 37's
'01 F250 Crew Cab 4WD -Tow Rig
Stic-o is offline   Reply With Quote Quick reply to this message
Old 09-27-2006, 01:10 AM   #5 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Here's some pics of mine. I wristed them a couple years ago but got tired of no turning radius and still crappy flex, not to mention the POS bayonette bushings... So I added 10" to them and a leaf spring bushing and moved the axle forward ~1.5". I angled the extensions up just a bit so the frame mounts wouldn't have to be so low (because otherwise your caster will be off). Plus heated them with a torch and used just about all of a 20t press to bend them. But now I'm pretty pleased...
The frame mounts are gusseted a bit more now as well...
In vino veritas
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote Quick reply to this message
