couple questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-27-2006, 07:31 AM   #1 (permalink)
Member # 57791
Send a message via AIM to Fresh469 Send a message via MSN to Fresh469
couple questions
i am thinking about buying an early 80's f100 and have a few questions....
would the stock TTB and rear axle hold up to 35's?
i pushed the brake pedal and it had a little resistance and then BAM, it hit the floor, what would cause that? i checked the brake fluid and its full, and i couldn't find any leaks....
Fresh469 is offline   Reply With Quote
Old 09-27-2006, 08:56 PM   #2 (permalink)
Member # 10063
That truck will have (depending on year/engine) a 8.8" or 9" rearend (both 31 spline), and a HP D44 front (TTB).
35s shoulnt be a problem if you don't get too stupid on the throttle.
If there are no leaks and the brake fluid is full, I'd suspect the MC.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 11-03-2006, 09:27 AM   #3 (permalink)
Member # 57791
well, the truck is a 81 f150 4x4....i think i am buying it......
would completely worn out brake pads cause the pedal to go to the floor? i was looking at it today and found a brand new set of pads laying in the floor behind the seat....
