how to get max flex on TTB - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-20-2006, 08:30 PM   #1 (permalink)
Member # 56307
i have a 1985 ranger and i changed my fron diff. from a danna 28 to a danna 35 from a 1994 ford explorer. i have a locker in the front and a spoul in the rear and 456 gears, im tring to get the most flex but i need some ideas.
i read a little and i found out that i can put jeep coils in the front has any one tried any other thing ? any ideas will help pics?
alexyz450 is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 09:15 PM   #2 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
www.therangerstation.com
masterbeavis is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 09:31 PM   #3 (permalink)
Member # 36271
Itís not an easy task, doable, but not easy. The locker you have will probably be your best friend. The one downfall with TTB is you donít get the opposing force on the dropping tire when you have an upward force on the other side. You can get up to 15-17Ē of wheel travel before the stock steering geometry is maxed, even at that it is maxed.
A few things to consider.
Longer Radius arms, do not just get radius arm drop bracket.
The longest shock you can fit (James duff Makes hoops, you can use an F250 mount, or fab your own)
Soft Springs (hence the jeep coil) of the proper length seem to help a lot.
Check out therangerstation.com as stated, theyíve got some tech there. Find out what your current limiting factor is and work from there,
Hereís a couple pics of my current set up, not amazing, but it gets me around, and Iím locked up front as well.
http://i15.photobucket.com/albums/a3...r/P3240001.jpg
http://i15.photobucket.com/albums/a3...r/P3210009.jpg
swiss is offline   Reply With Quote Quick reply to this message
Old 10-21-2006, 06:38 PM   #4 (permalink)
Sarge_AF's Avatar
Member # 79872
The best way to get flex out of a TTB is to rip it out and swap in a solid axle. I tried getting my BII to flex after I installed a D35, too. When I got my Xploder to build, I tried again with the TTB before I just gave up and swapped in the HP44. Not only does it flex better, it's a ton stronger. Sorry to tell you, there's just no way to get a TTB to flex like a solid axle.
Sarge_AF is offline   Reply With Quote Quick reply to this message
Old 10-21-2006, 07:49 PM   #5 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
WTF??? get outtah here.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 10-21-2006, 08:22 PM   #6 (permalink)
Member # 10063
Yeah, no flex here either
TRS has the info you're after.
Too many solid-axle-lovers here that can't be bothered answering questions about TTB junk
PS, its easier than you think, the biggest thing though is figuring out what spring rate you need and doing the math to get the right height coilsprings. Also, as swiss mentioned, the stock steering sucks, you may want to swap that out for something that uses a centerlink.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 10-22-2006, 09:28 AM   #7 (permalink)
Member # 41653
Im going FW 44 and sterling 10.25 this winter..its not flex Im after..its survivablity and STABILITY...ttb's are unstable with the steering/flex setup in the front..but heres what you need to do for more flex..
Longer arms OR short arms with HEIM joints on them at stock length..(or both)
I used stock coils..but my DD had EB coils in it and rode ALOT softer with stock arms..
longer/relocated shocks..
thats it...the longer the arms the more "flex" you will get out of that setup.mt explorer has 14in with the skycrapper 2 arms..the rear has an extra main leaf with the eyes cut off and 1 secondary and the overload..18in of travel on the back..
now with that being said...I REINSTALLED my swaybars front and back after several instances of severe body roll..its alot more stable now..and I still get close to that flex in the back..about 10in in the front..and it "feels" better...
it is possible to make a TTB35 flex like a solid axle...remove the center pivot brackets...weld the left and right beams together with steel plate..and make a panhard bar...flexes like a solid axle..
your front locker will end up causing you problems..my aussielocker works awsome..and has broken 3 driverside shafts...2 of them within an hour of installing them...for the ttb you really need a L/S up front to take the stress off the joints...the stock joints just dont survive anything over 33's and trail abuse..
and the d44 isnt ALL that much stronger that the ttb35 when talking about U-joints...but the 44 has a better aftermarket availability..
Gotta Love people who have "soon to have/be" in their signatures....Im soon to be thin,rich and nice..
yea right..
"They are little angels but they are trying to fuck the wings off each other!"
--Sturgell
Black eyes last but a week, the shame of sodomy lasts a lifetime.-TheRedHorseman
wanderer-RRORC is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 06:03 PM   #8 (permalink)
Member # 32844
Send a message via AIM to Matt8888
Best thing you can do is WELD the joints in the shafts on the D35. I ran a
2.9L /Auto in a standard cab ranger with a D35 welded and 35x15.5x15 SX's on steel beadlock wheels for 2yrs and only broke one shaft and a driveshaft. All depends on how stupid you get with the skinny pedal...
Matt8888 is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 06:32 PM   #9 (permalink)
Member # 23035
That makes it kinda interesting getting shafts in and outta the knuckle.. but its nice when your u joints dont pop outta the shafts.
[B]Kyle Prettyman[/B]
[B][COLOR="Red"]AzUndertakers[/COLOR][/B]
el ranger loco is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 06:37 PM   #10 (permalink)
Member # 32844
If you do it right its not a problem......
Old 10-24-2006, 07:18 PM   #11 (permalink)
Member # 23291
Send a message via AIM to ryan_nwu
jeep coils
but i'm still not sure i'd describe it as "mad flex"
97 X on 36s
ryan_nwu is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 07:46 PM   #12 (permalink)
Member # 57399
Send a message via AIM to Catfish Hunter
how bout some more info on doin it right?
Surgeon General's Warning: Living may cause dying.
Catfish Hunter is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 08:01 PM   #13 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
Sceep had the best answer.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 09:30 PM   #14 (permalink)
Newbie
Member # 80230
jeep cherokee axles go right under rangers and explorers with minimal effort.. start with sceep's solution and go from there...
fordraceboy is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 05:17 AM   #15 (permalink)
Member # 41653
but go with the dana 44 front axle..and leave the stock ranger/sploder rear..theyre stronger than the heep rear axles...(if your ranger has the 8.8)
the d30 isnt worth the trouble if your going to wheel it..
yea right..
--Sturgell
Old 10-25-2006, 06:25 AM   #16 (permalink)
Member # 67169
I agree 100% on the right length coil bit. I tried 2 different lift heights and they are still too short. I guess the 3rd time will be the charm. I'm now waiting on specs for new coils.
I just need longer coils.
Joel H is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 07:13 AM   #17 (permalink)
Sarge_AF's Avatar
Member # 79872
That's alot of travel Joel, but how are you going to fix the fawked up camber issue when you run longer coils? You tires will be running like \-o-/ My 86 BII did that with just a 2" budget coil boost. The cambe issues are the absolute worst part about the TTB. There's just no other way to say it, it's junk.
Old 10-25-2006, 07:29 AM   #18 (permalink)
Member # 67169
Oh Ye have little faith. Don't worry Sarge I've got proper lift bracekts. I'm only using the 4" pivot locations right now but If I go to a taller coil I can move them down to the 6" location.Actually right now with the coils I have I get a little /---0--\ of that going on. So I can go up an inch or so and still be OK.
I haven't even touched my camber bushings. They are still set from when this front axle was in the Ranger.
Face it Sarge if it wasn't for AKBroncoII You'd still have the stock suspension under the X.
BTW How's Alabama treating you?
Old 10-25-2006, 07:58 AM   #19 (permalink)
Sarge_AF's Avatar
Member # 79872
Nah, but I would still have the VMS brackets, and the TTB. Andrew cut me a hell of a deal on the 44/9, that's the only reason I was able to afford it.
As for 'Bama, I LOVE it! the laws are so slack compared to Alaska. The only problem is there's nowhere local to go wheel.
Old 10-25-2006, 09:10 AM   #20 (permalink)
Danger Ranger's Avatar
Member # 1234
this is the most flex I got out of my TTB
If not today nor yet tomorrow then some other day
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 09:13 AM   #21 (permalink)
Member # 42546
Is that what your truck started out looking like??
big specht is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 11:31 AM   #22 (permalink)
Member # 1234
YUP!
Old 10-25-2006, 06:36 PM   #23 (permalink)
Member # 42546
DAMN it changed just a littlebit that is a big differance from what it is now
Old 10-25-2006, 10:05 PM   #24 (permalink)
Member # 10063
Camber doesn't cause anywhere NEAR the handling issues fawked up steering causes. Throwing just the shitty stock steering in that dumpster is really all thats needed here.
But if the camber on droop still bothers you, you could always reduce it by running a limit cable or strap from one side over the frame to the other though (preventing both wheels from drooping out together as far, but still allowing articulation).
I actually tried this on mine... the biggest benefit I got from it, the damn hood doesn't rise up as far when climbing hills, you can actually see over it better.
Old 10-26-2006, 05:41 AM   #25 (permalink)
Member # 16024
The dreaded camber issue really isn't an issue until you hit max flex, and then it is on the trail, where in a lot of cases, it keeps a tire planted against the hill instead of running on the sidewall like the straight axles.
There are limitations in the TTB, but not half as many as has been suggested here. For trail use, you may be happier with one than with a light-duty straight axle. For more hard-core use, the straight axle will be the ticket, but there will also be trade offs in cost and ride.
I've about maxed mine out as cheaply as possible:
1. 1977 F150 3" lift coils
2. F250 shock mounts, modified to fit stud shock
3. 2006 Dodge 1 ton 4x4 shocks
4. Super Duty brake hoses
5. Clearance some areas that tend to hit
6. Worn rubber bushings on the radius arm ends
7. Remove anti-sway bars
8. C-clip removal modification
I measure right at 18" from top of travel to lowest droop at the hub.
Total cost to accomplish this travel (using a lot of cast off parts and general scrounging) -- less than $100. The money was spent on the shock mounts and Super Duty hoses. Everything else was free.
Oh, BTW, this is my DAILY DRIVER. Last year it DROVE to Moab, wheeled there and drove home. It DROVE to Panama City, parked on the beach for pics, and drove home. It DROVE to Pennsylvainia and back, and it DROVE to Wisconsin a couple times, not to mention all the local wheeling. NO TRAILER last year...
In the pic below, my tires are already at the level of the body sheet metal, but the springs are hardly extended... That means there is a bunch left to go...
This one shows it working on one side -- not as much camber issue -- and more typical for trail use.
I've been wheeling this rig for 3 years now on 33's in all sorts of terrain, and have ZERO broken parts.
I am also, however, building a Ranger SAS that will be setup for more hard core wheeling. I know the limitations of the TTB for huge rock piles, big tires, etc.
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote Quick reply to this message
