1995 5.8L engine specs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2006, 05:31 AM   #1 (permalink)
Member # 39709
Send a message via MSN to chuck911jeep
Hi!
I would like to know the specs(HP and torque) for the ford F-150 1995 5.8L injection engine. I would also like to know what is the difference between the normal and the lightning. Lot of web page don't tell the same thing about hp and torques lbs and they also tell about lightning performance. What make a lightning? Also, how can i boost this engine a little with minimal cost?
Thank's
Justin
chuck911jeep is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 10:57 AM   #2 (permalink)
Member # 48716
Send a message via AIM to VerticalTRX
The First gen. lightnings used a 351w with cast iron GT-40 heads instead of the stock E7TE truck heads. The GT-40 heads had 1.84/1.54" valves and bigger runners, as opposed to the 1.78/1.45 valves in the E7TE's. I might be mistaken, but I also believe they used a roller cam. I don't know the power specs on either, I'm guessing around 220-230hp, 300-320lb/ft for a stock 5.8L EFI, but I really have no idea. The lightning will be slightly higher.
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet
VerticalTRX is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 11:17 AM   #3 (permalink)
Member # 39709
Thank's, i appreciate
Old 10-24-2006, 09:13 PM   #4 (permalink)
Member # 54844
hp numbers
hi - 5.8 mass air fords have 210 hp@5000 and 315 tq @3000 - and factory roller cams - speed densidy 5.8 had 205 hp and 300 tq at the same rpm - the lightning ( first gen ) have the ubove mentioned gt 40 heads and intake - it looks more like a mustang engine ( single throttle body ) 245 hp and 340 tq - i have a 95 5.8 mass air with 255k and still runs great - ( though i dont think it still has the 215 hp )
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 06:50 PM   #5 (permalink)
Member # 39709
Thank's
The engine is 1995 and automatic(for now). I want to put it in front of a np435. Wich bellhousing and clutch it take? Had look at ebay but belllhousing and clutch compatibility engine seem to stop at 1994 concerning engine...What's the problem with 1995 engine? What do i need to put the np435? Do all the 351 have the same bellhousing bolt pattern?
Thank you!
Justin
Old 10-26-2006, 08:08 PM   #6 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
There's nothing different about a 1995 351w, it's just that by that point, the 4 speed was finally dead, and only the ZF 5 speed(integral bell) was offered behind it. Any 300 I-6, truck 302, or 351W bellhousing will work for your application. The fun part may be finding a flywheel, it needs to be from a 351W(mid 82-97 in a truck) or pre 81 302 to have the correct imbalance. I could probably round you up the parts here, but, by the time they were shipped, it'd probably be more cost effective to buy a new flywheel...
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 05:05 PM   #7 (permalink)
Member # 39709
Did the computer will be a problem?
Old 10-29-2006, 11:50 AM   #8 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
yes. It is used to having an auto transmission to control. You can probably get a chip made for it to make the computer ignore the fact there is no transmission. Your truck "should" run tho.
masterbeavis is offline   Reply With Quote Quick reply to this message
Old 10-30-2006, 03:24 PM   #9 (permalink)
Member # 39709
Thank's guys.
I will try in a couple weeks and let you know...for the computer
Old 04-02-2016, 11:10 AM   #10 (permalink)
Member # 663498
Just curious if the wiring harness from a 97 5.8 is different if I put the 5.8 in a 95?
Wildman69xxx is offline   Reply With Quote Quick reply to this message
Old 04-03-2016, 03:29 PM   #11 (permalink)
Member # 120478
What are you doing with the truck? If it sees the freeway I'd consider a ZF5. The ZF gets you overdrive and still has a respectable granny first. Little harder to find and generally more expensive though.
As others have said, basically any 4.9, 5.0 or 5.8 SBF manual transmission will bolt up to your motor.
Is your 95 MAF? Or was that just a CA thing? If so you'll likely run into some computer problems. I have a friend that a did a ZF5 swap on a MAF 95 so its certainly possible.
I put a ZF5 in my 90, unplugged the harness to the E4OD and the motor ran fine, didn't even throw a check engine light, it would idle high once in a while when stopped but really ran quite well.
90 bronco w/ tons, 4 shifters, 3 pedals and a steering wheel
Bay Area, CA 4x4 club - uc4x4.com
Dan90FSB is offline   Reply With Quote Quick reply to this message
